haul
Everything posted by haul
  1. Hi , take it in and have it looked at, they are easy to rebuild and does not cost that much, from memory mine cost 180 and you have a fresh starter again, dont waste your money on second hand as you can end up with the same problem. Cheers Tony
  2. Big thank you for your best wishes, its 600pm now wind is coming on stronger, still another 5 hours before it hits, around 11 pm, they are saying we can expect high cat 3 or low cat 4 winds here in townsville and around 1 metre of rain, 2 to3 metre storm surge. spent the morning boarding up the windows, only house in the street to do so. could not believe how many people are not taking it seriously, mostly new people from down south, comments like it is only cat3 wind, 170> 224 kph , cat4 225>279 kph, well I think they will be thinking different in the morning, power is flicking off and on so do not know how long we will have it for. Thank you all again for the kind wisher, Tim and I will keep you posted when we can. Cheers Tony
  3. Hi Tim, I use NULON SAE 90 which is API spec GL-5 / GL-6, it meets all euro,aust,jap,brit,usa specs, I use it in the skyline as the Z is a non lsd r200, you know what r31 diffs are like, it quietened it down a fair bit. Cheers Tony
  4. You are making me jealous, Now that I am on a break for Xmas, I will have to get the MSD sorted and get mine going. Be interesting to see a turbo against the LS, But I think it will be a no contest. Cheers Tony
  5. You can run rb30 injector out of a r31 skyline or vl commodore. Cheers Tony
  6. Having been their I know how dark it can be, Unfortunately some do not see the light around the corner, there is also the embarrassment, so many do not speak about it because you fear others will think you are weak , But as stated by other on this site we have been there and came back, so can you, you just need to talk to someone. R.I.P mate. Tony
  7. Peter, that would be good if you did that, as it would make it a easier option for those going the power steering option. Cheers Tony
  8. Peter, If you get the time could walk us through what you needed to do to fit the bmw rack, and confirm it was a 318 97 model. Cheers Tony
  9. Good to hear it is working out for you, appreciate the effort. Looking forward to buying a set. Cheers Tony
  10. Hi , Tim, there is a bloke here in Townsville who will certify new anchor points, had it done on one of my cars, I will see if I can find his name and number. Cheers Tony
  11. G''Day Jesse and welcome, I have a efi turbo running all standard equipment no intercooler on low boost and has been running like this for 9 years with no problems. Cheers Tony
  12. JDM Galant vr4, 1970 Dodge Challenger 426 Hemi, BMW 635 csi. Doesn't cost to dream.
  13. They were made in South Africa in 1977-1978 only about 300 made, they are based on the 120y, although they had a L14, twin 40mm dellorto carbs, made about 85kw. You could definitely have some fun with it. Cheers Tony
  14. This is what I got out of the book I have. Found this one , FS5W71B 260/ 2 seat 260/ 2+2 1st 2.957:1 2.906:1 3.321:1 2nd 1.857:1 1.902:1 2.077:1 3rd 1.311:1 1.308:1 1.308:1 4th 1.000:1 1.000:1 1.000:1 5th 0.852:1 0.864:1 0.864:1 rev 2.922:1 3.382:1 3.382:1 Tony
  15. Hi Peter , good price, let us know how it looks after few runs. Cheers Tony
  16. I run a n42 combo l26 turbo with standard compression 8:3:1 low boost 7psi all standard nissan efi gear; computer, turbo etc, although it has vl injectors hypertechnic dished pistons , grant rings and bearings. I have run this now for 6 years it goes like a cut cat and I have never had any problem with it, so if you don't go silly with high boost you will have a car that will give ample punch when you need it and will embarass crumbledoor,ford and wrx owner. It will give you a good starting point. cheers Tony
  17. Hi Garvice what would you be looking at for the turbo. Cheers Tony
  18. Hi Tim, If you need a hand let me know I was a panel beater and have done a few screens. Cheers Tony
  19. I was going to get a rebuilt one sent up from SEQLD,but I think I will leave it for now. As I don't really need one at the moment, it was only that it was a good deal but i missed out. Will have to get together for a chat seeing that there are very few of us auszcar members up here,may need to go shopping in your spare parts department. Cheers Tony
  20. Thanks for info, not as heavy as I expected. Cheers Tony
  21. HI all ,just wondering if anyone has weighed the r200. I am looking at getting one shipped up and it would help with working out cost of freight. Cheers Tony
  22. The round lights are high and low beam, the one on the bottom is the parker. as to the blinker you will need to change the blinker relay,and yes that switch is for the antenna. Cheers Tony
  23. G'day & welcome, I'm also from Townsville. Cheers Tony
  24. I have used rare spares, they are sometimes dearer but they are good to deal with. Tony
  25. Hi Ray, I have a l26 efi turbo, I am also here in QLD, and i run a pod filter, it used to have a well made home made airbox which sat between the radiator support and the grill. And yes It is illegal in QLD to have a pod filter, but is a much simpler set up. Cheers Tony
