Toecutter
Everything posted by Toecutter
  1. After a 6 week wait I've finally got my new 17" ROH wheels. 8.5 inch for the front and 9.5 inch at rear to be mounted with 225 front and 255 at rear. Looking forward to picking up the freshly painted ZG flares this coming week to fit all that rubber under. Hopefully they'll be on the car by next week! Sulio
  2. Evan, If you end up getting yourself a set of 3 peice wheels it will cost you about $150 per wheel to get outer sections made up if you want them wider for flares. Thats assuming the wheel sits nicely on the inside and does'nt hit the suspension perch. I think the best chance you'll have is finding something like a Simmons wheel if your after someting 2nd hand but be prepared to wait as I did but I ran out of patience. Good luck! Sulio
  3. HI Matt, just bring yourself along. All food and drinks will be supplied. It'll just be a basic bbq and a chance for everyone to say hello. I too am looking forward to getting down to COMO PARk for the show after the feed. Cheers Sulio
  4. I think you could run them on a 240/260 with a 10mm spacer which would cost about 5-10 bux each. Don't even think about flares with them though, just too narrow and offset way off what you need. Evan I'm not sure but I think they are one piece cast alloy wheels and the alan key bolts are just show. Sulio
  5. Good work Jimbo. I've heard this fix by some of the US guys with good success and like you said people drive around with huge towbars and don't get hassled so why would you. I found a significant improvemnt after the addition of a "dump pipe" on the tip. My exhaust is 2.5" with a tip a little bigger than that that points down. Very neat and looks quite tough at the same time. Cheers Sulio
  6. Just found a great thread to answer most of the above! http://forums.hybridz.org/showthread.php?t=103767 & http://forums.hybridz.org/showthread.php?t=104735 Sulio
  7. I've had a breif discussion with Gav about changing to rear discs. I believe the old Skyline R30 rear end is almost a direct bolt on to the 240/260 rear end. Has anybody got any pics or links to the parts needed? Apart from the caliper and disc I believe there is an "adapting plate" of some sort needed!? and I believe this is all that is needed!? Using the 300zx front brakes, can they be fitted to maintain 4 stud pattern? What parts needed! I believe they come in alloy as well as heavy steel sets!? If this is so which 300's had the alloy brakes? Just started searching for info on this one so it's all a big mystery. any input one be appreciated seeing I could most likely get these bits through a friend and stick em in the shed til after the L28 is done if I ever pick one up! :? Cheers Sulio
  8. oh and if you go for the option of glueing new vynil in place be sure to buy the thinner light weight vynil you can get from an upholsterer just so it sticks better. You could cheat and vynil paint it black but thats assuming your current lining is not the cloth type as my 240 has! Mine was cloth so I removed it and got the vynil in place instead, much prefer it and looks new again.
  9. An old add from Wheels magazine I think back in 74!
  10. I'm hoping my wheels are ready this week which means I'd be rushing to get the flares on in time for the CONCOURSE but I'll definatley drive down to check out the show after a few sausages!...and maybe next time enter the car in the show. Cheers Sulio
  11. Black.
  12. It was glass. Not sure about SU's but your better off getting them from OZDAT I think you will find them cheap there!
  13. Thats ridiculous! Man you've got some pretty selfish neighbours! Can't you just do the work behind closed doors!? I might know someone that could help you out with some factory space if they have room so you could finish the car off. I'll give you a call tommorrow some time with details. How far off are you from being ready to paint it? Cheers Sulio
  14. I believe radiators from the 260 auto's hang down a little lower but then again that might just have been a one off with a parts 2+2 car I had.
  15. No good at Z shop Mike. Did'nt get a chance to see Warren but I'm planning on dropping in tmorrw. Cheers Sulio
  16. hey Callum, good to see your pics. I've got an aftermarket woodgrain wheel with alloy center. I beleive they sell for about $250. Looks very nice but I noticed that during the Arthuers Seat cruise my hands had a little bit of sweat on them whilst gunning it uphill through the tight and windy corners. I found that the steering wheel got a little slippery and for practical purposes a rubber or vinyl steering wheel might work a little better. Cheers Sulio
  17. Vynil paint or dye is ok for panels but I would'nt recommend it for seats. That would be a little tacky and it would come off once your ass hits the seat a few times. JP240 just clean up the plastics with clean soapy water and let them dry thoroughly then paint. Be sure to let the first coat dry well before you apply the second. Do not try and complete the area with one coat seeing it will run, loose grain detail in the vynil and could even get ripples if it's real thick and the top drys quicker than the paint underneath. Cheers Sulio
  18. Hi Dale, Wow thats a huge collection. Is one of those new UK mags you've just recievd called MODIFIED RETRO CLASSICS or something along those lines? Have you got all those articls in electronic format ie can you put them on a cd rom? What are you waiting for regarding repairing your car? I was in Ballarat last Tuesday but was pressed for time so we'll have to catch up on the 13th Nov. See you then! Cheers Sulio
  19. Hi Guys, We've decided it would be a good time to have another BBQ and get together on Sunday 13th November. Our first meeting was at ZR240's factory which proved quite popular so lets give that another go seeing Ash has been kind enough to offer the location once again. For those who would like to attend try to make it there by 11.00am. BBQ from 11:30am-12:30pm. After a few sausages, some video action Ash has from Japan and in car action from his last car on the track the plan is to drive down to COMO PARK, Alexandra Pde, Sth Yarra for the Concourse D'Elegance Show and Shine to check out some more Zeds on show. http://www.ndsoc.com.au/mambo/content/view/51/1/ Ok so the time will be from 11:00AM-1:00PM Address is 4 Beaumaris Parade in Highett, Victoria. If anyone is having trouble finding the place I'd say Nepean HWY would be your best option for getting to the Highett area but of course that depends on where your travelling from. For members that are too far away to attend I'm sure there will be heaps of pics to follow on this one and I'm looking forward to having some fun with my video camera to add to our currenlty non existant media section. See you there! Cheers Sulio
  20. Hi Gav, yer I thought he meant just a hole but I am under the impression that welding in a piece of metal to that hole would be very difficult to do right and keep the correct curviture and no ripples in the roof assuming you did'nt go crazy with bog. My uneducated guess was that it would call for a new roof skin. Having said that if funds were limited rather than getting a replacemnt glass the old school vynil sunroof could be an option. Anyway moving on I noticed on another thread JP240Z is on a tight budget so I would recommend going down to Zshop in Glen Iris, I was there today and I noticed they have and old 240 parts car sitting outside with a sunroof, I'm sure you could get that cheap. Failing that just go to some junk yards and look for a second hand sunroofs to suit the dimensions your looking for. Cheers Sulio
  21. I think black goes well with all paint colors. What colour is the car?
  22. I met a fella in Oakleigh that just bought a 75 260 2 seater and it had the brackets so they must be around.
  23. Lynton is right if you've got the funds I would get a new roof. Unstitching the old one would be a pain. Might even be easier to just cut it at the pillars and weld in a new complete roof but thats just a guess on my part, because I think ZR240 just did that. Anyway anything you could do to close up the hole would certainly help with value. Most people that really like these cars know that they did'nt come out with sunroof. I'm one of those that see it as a "bastardization" of the car. I know it can be costly to repair so rather than putting in a glass sunroof I would opt for the black vynyl square sunroof that pulls back. I don't know much about them but i think they look the part. good luck whatever your choice sulio
  24. I discussed this one with Mike on the phone. I've got a couple of parts to check out at Z Shop this Saturday so I'll check there and I'm going to see Warren from Zworx this Sunday. If neither of these guys can source these brackets then my guess is it would be quite hard tracking one down in Australia. Cheers Sulio
  25. In that case probably best to enquire with nissan here in Melbourne.
