I think this is why I have 4 240z's to be honest. I like originality, but I also like period correct modifications and some improvements to make the cars a bit more fun.
The older I get, the more I appreciate them the way they are or were made. I do like an RB swap (26) in concept, but I feel the chassis isn't really up to the task and to me it's a bit of a mismatch when you consider the Rb26 was AWD in a GTR.
I feel like 250hp in a Z is plenty of fun and can be achieved via the L-series engine. Engine swaps always date the car to an era and the RB motors are old hat now.
The only engine swap in an S30Z that really appeals to me is the S20 motor, but they are now worth an absolute fortune and out of reach. I almost think I'd be better off doing a tribute 432-R with an O.S Giken Twin Cam head on an L-block W/Triple 50mm Solex on it. Price would probably come in, under what an S20 build would cost these days and has nearly equal allure (specialness about it)
The other build that appeals to me is an L28 with HKS surge tank and turbo charged for that 80s era Wangan racer vibe, but fuel injected (and aesthetic wise, using throttle bodies that give the blow thru carb turbo look).
But if I was to do a swap I'd try to ensure everything could be reversed later should I wish to revert to standard.
Finding good original cars is really getting difficult and as time goes by the OEM parts are actually becoming increasingly expensive. AM radios, early ash trays, antennas, hub caps, steel wheels, early style valve covers etc.. all drug money now.
I really do think if you're looking long term original is the way to go. But that doesn't mean you can't make the car fun also. For example I love Triple carbs on these cars and find SUs a bit pedestrian.
But swapping between them isn't a big deal. On my 71 which runs an auto box, I'll keep the SUs and I'm thinking I'll keep the original points distributor but swap the points for a pickup style ignition (like Pertronix) and keep the vacuum advance set up.
Where as on my 72 with Triples I haven't got vacuum advance, run an electronic dizzy and will probably add in a CDI box at some point, that car will also get things like LSD, 4.1 ratio rear end, MK63 calipers, Watanabe wheels (or MSpeed Work Rally Mag Replicas) and has Ikeda Bussan Seats, Rally Clock and Datsun Compe wheel. All period correct mods and updates and I find that car a lot more fun and lively to drive, but also less civil, fumey and noisy.
Each car has its own personality and character, but that's what's fun about them.
Regarding the value of old L engines, I think you'll be surprised in future, I'm seeing less and less available these days and already in Japan I'm seeing pretty high prices for basic blocks. What used to be $200 long motors is now $5k-$6k engines. I think that will eventually ripple through here and in other markets. Nissan used the L-engine for years and in many cars which is good, but try find them now. Only a handful for sale at any given time (if lucky).
