In my 260 ive got the auto centre console but its had a manual conversion done (280zx box) and what im wanting to know is there any differences between the 2 seater and 2+2 manual centre consoles in terms of lenghts and mounting points? ive done a bit of searching on the fourm but i cant seem to find exactly what im looking for.
As ive considered trying to repair my console as it has a few cracks here and there but the passenger side part is pretty warped (from excessive heat id assume?) so i figured if would be worth finding a second hand 2+2 console if it would fit.
Matty
Matty
They are easy to plastic weld, dont try glue or fiber glass as it wont work long term.
The warpage is an easy fix, take a heat gun or even a powerful hair dryer, heat from the inside of the console
Take two strips of wood once the plastic become maluable from the heating slide one along the inside the other along the outside and use a few small clamps to compress the plastic between them straight.
After a minute the plastic will set again, remove clamps, fixed
Repeat process if required until desired effect is achieved.
John
Thanks John
looks like it will give me something attempt to do over the weekend and ill see how i go.
Matty
... take a heat gun or even a powerful hair dryer, heat from the inside of the console
Would a hair straightener work??
thanks scoota im pretty sure that mines from 2+2 after all as it has the hole in the back but no ash tray
haha using a hair straightener, i dont think my missus would approve
hmmm rapid fix might be worth a look into.
We could always borrow one off Benji to find out! Ha! Says he who is thinning!
No can do... i dropped it and the ceramic plates broke.... was not a good day ::)
I know exactly where that came from LMAO
Maybe I should have tried using one on that roof of yours rather than tearing the ligiments in my shoulder over 2 days of bashing out those dents left from the Eatern European folklaw dancers that used it as a stage to perform on.
The 2-seat & 2+2 consoles are the same, except the 2+2 has the ashtray in back whereas the 2-seat deletes the ashtray & has a clip-in blanking panel instead.
