These will join the rear subframe to the existing floor rails and help strengthen the body so it won't twist.
$85.00 for the pair.
Pick up from Thomastown Vic, or can post Aus wide at cost.
  • 4 weeks later...
Looks to me like you can't fit the rear sway bar now...
True a forward facing sway bar - but if you get the sway bar that comes with the new rear hanger thing that mount the bar behind you are good + those rear sway setups work better on a lowered zed ;)
Could a small birds mouth or 'v' shape be cut into the backside to give the bar clearance? Similar mod to what Dave and Craig did on their power steering conversion.
Yep, best bet is to run a sway bar at the back of the diff (if you decide to run one at all).
You could notch out the rails but that would sort of defeat the purpose of strengthening that area anyways.
