Take one very rusty & chassis damaged 2+2:
Then use a plasma cutter & angle grinder to cut through the back of the floor & the bottom of the A-pillers:
Pull it apart & you have your very own Rickshaw! Yeeeeeeeeeeehaaaaa!
Bigfella?! Your rear cut is ready!!!
(Appoliges for the blurry photos).
I like it, all you need is someone on the roof with a whip. very gladiator.
Make a time Lurch and I will be there.
Thanks
