mossy Posted May 22, 2010 Posted May 22, 2010 Anyone have any tips for removing an old rocker cover gasket that's rock hard, I've tried a blade and it barely comes off, I thought maybe soak it in thinners? Quote
chris240 Posted May 22, 2010 Posted May 22, 2010 eucalyptus oil... or very carefully dab on some gel paint stripper.. Quote
Moderators Zedman240® Posted May 22, 2010 Moderators Posted May 22, 2010 Wire wheel attachment on grinder or bench grinder. Works for me.. Quote
mossy Posted May 22, 2010 Author Posted May 22, 2010 Thanks, now which option to choose, I'll go the cheap way first and use the wire wheel, don't kmow why i couldn't come up with any of these options myself Quote
peter t Posted May 23, 2010 Posted May 23, 2010 If you wire wheel you will get a very uneven surface and most likely oil leaks. Go the gasket remover and a bit of elbow grease. Quote
Mr240z Posted May 23, 2010 Posted May 23, 2010 If you wire wheel you will get a very uneven surface and most likely oil leaks. Go the gasket remover and a bit of elbow grease. No you wont...I done a thousand of them. Quote
Moderators Zedman240® Posted May 24, 2010 Moderators Posted May 24, 2010 I've done it many times with thermostat housings etc and never apply too much pressure; just enough to remove any old gasket material and that's it. Never had any issues of warped / leaking housings. Quote
MaygZ Posted May 24, 2010 Posted May 24, 2010 A lot of housings are Aluminum so care must be taken. A brush, especially brass, should, in my opinion, be fine to strip an iron block. You'll probably get the deck milled/trued alway? Right? Quote
