Just thought i would put it 'out there' I need to put in a 15amp external powerpoint to run my new compressor and thought someone on the Forum may know of someone?
Rev.
got the same deal with my welder.
I bought a 15A female plug and a cheap extension lead, 1+1 makes 15A power cable adaptor ;)
Just make sure you have auto circuit breakers.
To this day almost 8 yearrs after doing it i have only ever tripped the breakers once and that was because i was welding something really thick, the welder was up at full power.
You could just grind down the earth pin on the 15A plug to fit a 10A socket... but depending on the quality of your wiring, circuit breakers, etc your house might burn down.
It's worth spending the $ on a registered sparky.
Rev,
I bought this adaptor lead from home to Van 15amp to home 10amp 240V adaptor off eBay. Would this do the job? Cost was $160- and had a circuit breaker or trip switch on it. Might be cheaper than an electrician and easier? The link won't work but I can get you more details if you like. PM if interested.
This is what I have done, except the 'cheap' extension cord.  I cut down a quality 15A cord (to keep the inlet side as short as possible for obvious reasons).  I have never had a problem.  The power in my shed runs on a seperate fuse from the main board and is fused again at a fuse box in the shed.  I've had a mate, who is a licensed sparkie, check it out and he assures me that it is completely safe.
for your info.
Maygz, i have a mate whos a sparkie who shakes his head at my patch cord and walks away. ;D
yea, not ideal i know, but im in rental properties, its not feasible to get things constantly rewired.
Once i buy a house though, the shed will have 15A outlets next to all the 3 phase outlets 8)
Im not a fan of grinding the earth pin, its very unprofessional and borders on ghetto.
Hey Dave! Long time no See, But im a Signy as you know, But i work with a B Grade Sparky, - Put the signs up And Wire them, Best guy for ya, Cash work, And perfectionest + 51 so knows exactly what hes doing, Message me if your interested mate. Ill give you his number and let him know!
