Nissan L Series - 6 Cyl Head Gasket Laminated 91mm X 2mm A$410.00 (inc)
dam you would want to make sure you pulled the head down right  I would hate to have to buy it more than once :o :o :o :o :o :o :o :o :o
That would be for a metal head gasket = reusable we use these about 8 time - with copper coat sprayed on.
oh that is more like it so it just needs annealing and then you can re use it. I thought it was a fiber gasket. But still i didnt think they where quite that dear
  • 3 weeks later...
Mob called "Gassol" in northern suburbs brisbane can make whatever you need in copper, he is ex ACL.
If using the MLS ( Multi layer Steel) at $410, look to surface the head and block at at least 40ra smoothness to give superior seal.
I use to use the MLS, but found re-sealing was an issue, I know use a "pro-torque", with 40ra, it gives me what I need.
There was a guy out in the Dandenongs that makes head gaskets and also a crowd down Frankston that makes copper head gaskets. Sorry can't remember further details but a look at the yellow pages or do a google search might turn up the info you need. Quality of the Dandenongs job was first class.
pcs  8)
