Hi guys, recently I've been searching for after market parts and thought I'd start a thread that would help others. This is due to the fact that some parts are getting scarce and thus manufacturers are starting to remove the part numbers from their catalogue.
*Disclaimer: This list is for compilation purposes. Please confirm model with manufacturer and also confirm with an expert if it fits your application. I take no sole responsibility for misinformed purchases.
Feel free to post and I'll add to this list. I'll compile it. If possible can we get this thread stickied?
Whiteline Sway Bars[240Z] Front HD: BDF7 Discontinued
Whiteline Sway Bars[240Z] Rear HD: BDR30 Discontinued
Whiteline Sway Bars[280ZX] Rear HD: BNR5 Discontinued
Whiteline Sway Bars[260Z] Front HD (Blade Adjustible): BDF7Z Discontinued
Whiteline Sway Bars[260Z] Front HD: BDF7 Discontinued
Whiteline Sway Bars[260Z] Rear HD (Blade Adjustible): BDR20Z Discontinued
Whiteline Sway Bars[260Z] Rear HD 70-73 without OE sway bar: BDR30 Discontinued
Whiteline Sway Bars[260Z] Rear HD 70-74 with centre dip: BDR7 Discontinued
Whiteline Sway Bars[260Z] Rear HD 74-79 without centre dip: BDR20 Discontinued
K&N Oil Filter (all L6 series engine): HP-3001
k&N Air Filter[240Z] (oval shape for original air boxes): E-2910
k&N Air Filter[260Z] (oval shape for original air boxes): E-2900
k&N Air Filter[280ZX]: E-2880
Whiteline Strut Bar[260Z] Rear: KSB609
Cusco Strut Brace Front AS model: 246 510A
Cusco Strut Brace Rear (2 seater only) AS model: 246 511A
Cusco Strut Brace Front OS model: 246 540A
Cusco Strut Brace Rear (2 seater only) OS model: 246 541A
Cusco Pillow Ball Upper Mount (Non-Adjustible) [240Z]: 246 411 A70
Cusco Roll Cage (2 seater only) 4 point type: 246 270 C20 (steel)
Cusco Roll Cage (2 seater only) 5 point type: 246 270 D20 (steel)
Cusco Roll Cage (2 seater only) 5 point type: 246 261 D (chromoly)
Cusco Roll Cage (2 seater only) 6 point type (avoids dash): 246 270 E20 (steel)
Cusco Roll Cage (2 seater only) 6 point type (avoids dash): 246 261 E (chromoly)
Cusco Roll Cage (2 seater only) 7 point type (avoids dash): 246 270 F20 (steel)
Cusco Roll Cage (2 seater only) 7 point type (avoids dash): 246 261 F (chromoly)
Cusco Roll Cage (2 seater only) 8 point type (avoids dash): 246 270 G20 (steel)
Cusco Roll Cage (2 seater only) 8 point type (avoids dash): 246 261 G (chromoly)
Wasp Tie Rods: WTE860L/R
ARP Head stud kit: 202-4206
Ryco Tall oil filter: Z115
Rear Wheel Bearings:
Outer Bearing B31Z-16C4
Inner Bearing RLS10-T-C4
Seal 43232 E4100
cool i was going to suggest a thread like this. i have been buying a heap of brake/clutch/gearbox parts lately so I will add these when i get a chance :) maybe people could post here and you update the first post, and have sections etc
  • 1 year later...
Hi guys,
if anyone has details of parts please post here or pm me. I'd like to get this thread growing.
On a side note. Outer tie rod ends, seems to be no longer available. I've tried several places. Most of these manufacturers have discontinued production within the last 12 months. I'll check Autopro tomorrow, over the phone they said they could get them for $33/each.
  • 1 year later...
Or you could help out a independent store like mine :)
I have them on the shelf in stock. (no problem with supply)
I usually do them for around $32.50 ea
Great idea though to put this up :) If you need help with part numbers for anthing else let me know as I have a lot of the old books.
Ash
Moorabbin Auto Spares
Ash, would you be able to get the uni joints for the half/tail shafts? and the $$ would be great too...
Oops.. I'd much rather buy from you, I wasn't aware that you sold them..
Next time I'll check before buying.
Part number and price as follows:
RUJ-2028 Half shaft universal joint
$28.50ea
RUJ-1781 Front or rear tail shaft universal joint
$26.90ea
Unfortunatly I cannot get a complete bush kit, being trying to get a source o/s but not having much luck (alot of the suppliers dont even answer emails?)
No problems Mikey, it seams that stuff people ask for I dont have and stuff they dont I do have lol.
Ash
I completely forgot about this thread!
SuperPro Bushes available through Fulcrum Suspension (quotes as of Feb 2012)
SPF0050K  NISSAN-STEERING COUPLING          1.00 EACH 56.29
SPF0033K  NISSAN-RACK MT                            1.00 EACH 30.88
SPF0104K  NISSAN-ST/BUMP STOP                    2.00 EACH 50.04, 100.08
SPF0927K  STRUT BAR TO CHASSIS BUSH KIT    1.00 EACH 45.03
SPF1215K  NISSAN 240Z/260Z Fr LOWER INNE  1.00 EACH 63.54
SPF0246K  NISSAN-DIFF TO C/MEMBER              1.00 EACH 70.76
http://www.superpro.com.au/index.php?option=com_vehiclelookup&view=vehiclelookup&Itemid=191&listMake=49&listModel=113&listSeries=166&button=Search+Now
Lowered King Springs:
240z Front: KDFL-8
240z Rear: KDRL-9
Koni Red Shocks:
240z Front: 86-1811
240z Rear: 86-1812
IBS Brake Parts (through Repco)
(should fit all 240's and 260's? 280zx master cylinder has offset mounting holes, the slave would be the same though)
Clutch Slave: IBS-JB4055
Clutch Master: IBS-JB1498
K&N Air Filters:
(I believe the 73 had a different height filter, and the list these filters as 240z from 70-75, 2.4 litre L6 which is obviosuly wrong. I would assume E-2910 for earlier models and E-2900 for later models but best off measuring it and checking it against the dimensions on the website http://www.knfilters.com/air_filter/nissan_240z.aspx)
240z:
1975 NISSAN 240Z 2.4L L6 CARB Air Filter E-2910
1974 NISSAN 240Z 2.4L L6 CARB Air Filter E-2910
1973 NISSAN 240Z 2.4L L6 CARB Air Filter E-2900
1972 NISSAN 240Z 2.4L L6 CARB Air Filter E-2910
1971 NISSAN 240Z 2.4L L6 CARB Air Filter E-2910
1970 NISSAN 240Z 2.4L L6 CARB Air Filter E-2910
260z:
1976 NISSAN 260Z 2.6L L6 CARB Air Filter E-2900
1975 NISSAN 260Z 2.6L L6 CARB Air Filter E-2900
1974 NISSAN 260Z 2.6L L6 CARB Air Filter E-2900
NGK Spark Plugs: BP6ES
Valvoline Oil Filter: V010
  • 5 months later...
Posted (edited)
Brake pads for the Sumitomo calipers:
Bendex: DB86
Ferodo DS2500's: FCP167H
    "        DS Performance: FDS167
240Z brake shoes: DBAS1350
7/8 Brake Master Cylinder: JB1133 (Protex Brand)
240Z rear wheel cylinder kit: K932S (Partswise brand)
Early 260Z rear wheel cylinder kit: K850S
Front wheel bearings: 2837KIT
Rear wheel bearings:
B31Z-16C4 (outer)
RLS10-2RS
Seal: 400732N - LYO Brand (seal also fits Landrover transfer case output!)
Tie-rod ends (Roadsafe Brand):
TE860R
TE860L
Koni Yellows (Z31 Fronts, 4 required - modifications need to make them work): 8641-1060SPORT
KYB Strut bump stops & boots: SB5192 (4 needed)
SuperPro:
Front Sway Bar 22mm SPF0569-22k
Rear Sway Bar 20mm  SPF1143-20k
Nissan Genuine:
240Z Air Filter Element: 16546-E3210
240Z Fuel Tank Sender Unit: 25060-E4100
Oil filter: A5208-43G0A-01
Kia Genuine Door Seal (via eBay): 0K018 58760B
Mechanical fuel pump: MFP-051M
Mackay manual pedal pads: PP1100
Edited by C.A.R.
  • 4 weeks later...
Does anybody know which oil pressure sensor/sender to use on the L26?
Possibly a fuelmiser brand? That is what repco keeps and is easy for me to get.
