240ZBUILTBYME 43 Posted December 2, 2020 Share Posted December 2, 2020 Hi all Just hunting for any second hand components in decent condition for a 45mm triple weber set up for L series engine. Ryan Quote Link to post Share on other sites
smugley 70 Posted December 2, 2020 Share Posted December 2, 2020 Hi Ryan just purchase new , don't think that second hand will be cheeper ! By the time you get something second hand , strip , sonic bath / hydroblast , new gasket kits ect then you find they have been modified/messed with and the shaft's & butterflies are stuffed , blocked passage ways etc ! I did the above with a set of 44's that cost $1500 , a couple of hundred less than a set of new Weber's at the time and ended up spending close to $3.5k without air filters . New Weber's will work out cheaper with out the headache's . Just my 2 cent's Doug Quote Link to post Share on other sites
240ZBUILTBYME 43 Posted December 3, 2020 Author Share Posted December 3, 2020 3 hours ago, smugley said: Hi Ryan just purchase new , don't think that second hand will be cheeper ! By the time you get something second hand , strip , sonic bath / hydroblast , new gasket kits ect then you find they have been modified/messed with and the shaft's & butterflies are stuffed , blocked passage ways etc ! I did the above with a set of 44's that cost $1500 , a couple of hundred less than a set of new Weber's at the time and ended up spending close to $3.5k without air filters . New Weber's will work out cheaper with out the headache's . Just my 2 cent's Doug Thanks for the advice Doug! I wasn’t sure how much a second hand set went for tbh. Was just putting the feelers out. I was looking at this set up which seems reasonable but not sure if it’s exactly what I need or not? Quote Link to post Share on other sites
AndBir 260 Posted December 3, 2020 Share Posted December 3, 2020 2 hours ago, 240ZBUILTBYME said: I was looking at this set up which seems reasonable but not sure if it’s exactly what I need or not? You need to know what the final specs of your engine will be prior to getting the dcoe carbies, as you do not want to have to change the "standard" jetting/tubes etc. as this can be expensive. Quote Link to post Share on other sites
240ZBUILTBYME 43 Posted December 3, 2020 Author Share Posted December 3, 2020 40 minutes ago, AndBir said: You need to know what the final specs of your engine will be prior to getting the dcoe carbies, as you do not want to have to change the "standard" jetting/tubes etc. as this can be expensive. Thanks Andy! More research required I’m thinking. When are you off east? Quote Link to post Share on other sites
Champ54 6 Posted December 3, 2020 Share Posted December 3, 2020 Hi, I have 3 new FAJS (Chinese Weber knock offs) that I am no longer going to use. I will sell them for $350.00 each if his will help. You would need to get a manifold and linkages. The jetting is: mains 145 emulsion tubes F16 idle jets 55F8 Needle and Seat 2.00 i bought these about 2 years ago to use on my Datsun 260Z. I thought they were the genuine Webers. Due to a medical problem I had to put my project on hold and have only recently been able to get started on it again. After I realised they are the JAFS 45DCOE carburettors I have decided to replace them. Best regards, Barry Sharp bsharp05@outlook.com Quote Link to post Share on other sites
AndBir 260 Posted December 4, 2020 Share Posted December 4, 2020 23 hours ago, 240ZBUILTBYME said: When are you off east? Maybe January. Quote Link to post Share on other sites
240ZBUILTBYME 43 Posted December 10, 2020 Author Share Posted December 10, 2020 On 12/3/2020 at 3:47 PM, Champ54 said: Hi, I have 3 new FAJS (Chinese Weber knock offs) that I am no longer going to use. I will sell them for $350.00 each if his will help. You would need to get a manifold and linkages. The jetting is: mains 145 emulsion tubes F16 idle jets 55F8 Needle and Seat 2.00 i bought these about 2 years ago to use on my Datsun 260Z. I thought they were the genuine Webers. Due to a medical problem I had to put my project on hold and have only recently been able to get started on it again. After I realised they are the JAFS 45DCOE carburettors I have decided to replace them. Best regards, Barry Sharp bsharp05@outlook.com Thanks for the offer Barry, but I’m gonna go genuine if I go anything other than SU Quote Link to post Share on other sites
d3c0y 269 Posted Thursday at 05:26 AM Share Posted Thursday at 05:26 AM I have a set of early Italian 45DCOE13s with stacks but they need the progression holes fixed as they have been modified for alcohol. A carb repair place can do this pretty easily if they have the jig. Let me know if you are interested. Quote Link to post Share on other sites
