cruzer Posted July 20, 2020 Posted July 20, 2020 Hi all, I will be putting in a L28 into my 260z. As the L28's don't come with the eccentric cup washer that mounts on the front of the cam gear to operate the mechanical fuel pump, I can't install the mechanical fuel pump. So my next option is to get an electric fuel pump. What fuel pump is everyone using? Any of them quite while in operation? I'm guessing I need a max of 3-4 psi to keep it going. Quote
Roady Posted July 20, 2020 Posted July 20, 2020 (edited) Hi I use a carter p4070 - very noisey though but been reliable for 7+ years. You could probably source the eccentric cup washer if you wanted to keep running the standard mechanical pump. I ran mine that way for years also. Edited July 20, 2020 by Roady Quote
cruzer Posted July 21, 2020 Author Posted July 21, 2020 Hi Roady, Where is your fuel pump mounted? Are you running SU's or webber's? Are you also running a FPR? Quote
C.A.R. Posted July 21, 2020 Posted July 21, 2020 (edited) Carter Rotary Vane pump - no need for a FPR: https://www.ebay.com.au/itm/Carter-Universal-Rotary-Vane-Electric-Fuel-Pump-P4070-12V-72-GPH-4-TO-5-3-4-PSI/302085863555?epid=9028927065&hash=item4655b87883:g:o48AAOSwL-9ccHAC&frcectupt=true Edited July 21, 2020 by C.A.F. Quote
Roady Posted July 21, 2020 Posted July 21, 2020 The link Locky posted above is the one. I ran it originally with SU’s with the plan to install Weber’s (which is now what I have on the car). Its installed right at the back right beside the fuel tank (with electric pumps, it generally helps prevent vapour lock having it close to the fuel tank). Jason Quote
cruzer Posted July 22, 2020 Author Posted July 22, 2020 (edited) Thanks Jason/Locky, I'll look at purchasing that pump then. just have to figure out how to keep this pump running quite now hahaha Edited July 22, 2020 by cruzer Quote
CBR Jeff Posted July 22, 2020 Posted July 22, 2020 If you are mounting the pump under the car at the tank there is already (normally) a wire (Green) in the std harness that is for an electric fuel pump. Runs from a plug at the fuse box to the tank with the fuel gauge sender Jeff Quote
cruzer Posted July 22, 2020 Author Posted July 22, 2020 Thanks Jeff, These pics will help loads! how do you wire this so that the pump turns on and stays on with ignition in position 1? I found this article which answers most of my questions except the one above https://www.classiczcars.com/forums/topic/45486-240z-electric-fuel-pump-installation/ Quote
CBR Jeff Posted July 22, 2020 Posted July 22, 2020 I picked up a wire (sorry cannot remember witch one) at the fuse box that was active when the ignition was turned to position 1. It was in the loom. I used this to tell the computer that ignition was on. Then ran the fuel pump output through a manual switch on the dash into the plug in the picture. Using the wire in the harness to connect to the in tank fuel pump. Im running EFI. The separate switch is a safety and anti thrift device so you cannot just start the car. If you have a dig around with a meter I am sure you will find the a wire that is energised with the ignition. Jeff Quote
AndBir Posted July 22, 2020 Posted July 22, 2020 Is a collision safety cut out switch (inertia activated) recommended for electric fuel pump installations? Quote
cruzer Posted July 23, 2020 Author Posted July 23, 2020 21 hours ago, CBR Jeff said: I picked up a wire (sorry cannot remember witch one) at the fuse box that was active when the ignition was turned to position 1. It was in the loom. I used this to tell the computer that ignition was on. Then ran the fuel pump output through a manual switch on the dash into the plug in the picture. Using the wire in the harness to connect to the in tank fuel pump. Im running EFI. The separate switch is a safety and anti thrift device so you cannot just start the car. If you have a dig around with a meter I am sure you will find the a wire that is energised with the ignition. Jeff Thank Jeff. I'll poke around the wiring loom and figure it out. 16 hours ago, AndBir said: Is a collision safety cut out switch (inertia activated) recommended for electric fuel pump installations? My thinking is you need to stop the fuel flow in a event of an accident. Last thing you want the car to do is catch on fire! I've looked into inertia switches as well, and apparently the Ford BF Falcon has these on the passenger footwell somewhere. I'll check out my local wrecking yard and see what I can find. Quote
