Hey guys, i purchased a set of new engine bay chasis rails from Zedds.... i notice that the old rails toward the radiator have a taper... the Zedd rails do not... in theory... i would have to drop the new rail every so slightly to keep it in a level position.... does this matter ?
Do i need to modify the Zedd frame rail to give it the "drop down step"? Or moving it down that little bit will suffice?
You cant move the whole rail down, as it wont line up to the skirt.
They have to fit into the radiator support panel, so if you have to modify them by inducing a taper, then do so.
  • 7 months later...
This is really disappointing. I just ordered some from msa, which I believe are zedd findings ones. They’re not cheap and you’d think for the price they would at least not have to be modified...
