260z blues Posted January 26, 2020 Posted January 26, 2020 Looking for a good condition drivers door for my 260z 2 seater. March 1976 model. Preferably sydney area unless your willing to ship. Thanks. Quote
260z blues Posted January 26, 2020 Author Posted January 26, 2020 Standard rust along the bottom but also some bad rust throughout the area where the door hinges are. Repairable but if i can start with a better frame then thats my prefered route. Quote
240ZR Posted April 17, 2020 Posted April 17, 2020 Which latch does it have, same as the 240Z or the later 260Z? Quote
gilltech Posted April 18, 2020 Posted April 18, 2020 (edited) It's the earlier style, identical to my '74. The later style has a circular latch plate on the body door jamb. Edited April 18, 2020 by gilltech Quote
260z blues Posted April 19, 2020 Author Posted April 19, 2020 23 hours ago, gilltech said: It's the earlier style, identical to my '74. The later style has a circular latch plate on the body door jamb. Thankyou for that. So 240z doors fit then ? Helps when looking for parts, still so much to learn about these cars. Quote
gilltech Posted April 20, 2020 Posted April 20, 2020 A 240Z door will look OK externally but the inside face is wrong as the internal door trim / pull handle etc is different between the 240Z and 260Z styles. Also, the 240Z and 260Z window winder mechanisms are different, both in component geometry placement and the way in which the winder spring mechanism is mounted - have a look at images online and you will see what I mean. Maybe it's possible to do a cut'n'shut of the two types, I'm sure someone will have tried it. Quote
260z blues Posted April 20, 2020 Author Posted April 20, 2020 7 hours ago, gilltech said: A 240Z door will look OK externally but the inside face is wrong as the internal door trim / pull handle etc is different between the 240Z and 260Z styles. Also, the 240Z and 260Z window winder mechanisms are different, both in component geometry placement and the way in which the winder spring mechanism is mounted - have a look at images online and you will see what I mean. Maybe it's possible to do a cut'n'shut of the two types, I'm sure someone will have tried it. Thanks. So looking for a 260z specific then really. Narrows it down a bit lol Quote
Mick747 Posted December 1, 2020 Posted December 1, 2020 have a drivers door late model 260z 2 seater, as brand new, no rust no repairs, been in dry storage for 35 years, Quote
260z blues Posted December 1, 2020 Author Posted December 1, 2020 From.what I've been told I need the earlier style but I'm curious anyway lol. Send me a pm Quote
