aircobra Posted September 20, 2017 Posted September 20, 2017 tried to change in oil, but the diff drain plug ( 1/2 square "?) is just behind the rear crossmemember. so can't get either a socket driver or a cross bar in there. seems to be ~5mm short of space do i need to drop the rear cross member to get access and leave the diff hanging by the moustache bar? is there some tool i need to get? Quote
Agno Posted September 20, 2017 Posted September 20, 2017 If it's anything like the later Nissans it would be a 13mm square and not 1/2". I nearly destoryed the fill plug on my old R33 trying to open it with a 1/2" ratchet because the difference in size was enough to round the hole. Quote
scott Posted September 20, 2017 Posted September 20, 2017 http://ktc.jp/catalog/index-category/category-list/ac301-10__17 Quote
road rider Posted September 20, 2017 Posted September 20, 2017 http://ktc.jp/catalog/index-category/category-list/ac301-10__17 It's all Japanese to me Quote
gilltech Posted September 20, 2017 Posted September 20, 2017 Just stick a jack under the diff, drop the moustache bar out of the way, and a 1/2" socket handle - that's always worked for me; you could always slip a metal shim in alongside..... Quote
aircobra Posted September 20, 2017 Author Posted September 20, 2017 this is them http://www.ebay.com.au/itm/DATSUN-13mm-SQUARE-DRAIN-PLUG-SOCKET-KTC-TOOL-For-NISSAN-B10-B110-B210-B310-/221712660741 http://www.company23.com/521 lots of scary stories about people using the 1/2 and wrecking the plug with the second design will have to drop the mount Quote
44014 Posted September 20, 2017 Posted September 20, 2017 Alum foil and ratchet. Has never failed me. Quote
