daretobedifferent Posted December 12, 2016 Posted December 12, 2016 (edited) -- Edited July 13, 2023 by daretobedifferent Quote
George Posted December 12, 2016 Posted December 12, 2016 Before you decide to purchase read up on galvanic corrosion and the differences in tensile strength of stainless steel bolts compared to your original steel ones. Pay careful attention to locations that do require a specific tensile strength. I haven't looked at the bolt kits you linked to recently but have done my research a couple of years ago and will not be using a single stainless steel bolt on my car. gav240z 1 Quote
daretobedifferent Posted December 12, 2016 Author Posted December 12, 2016 Before you decide to purchase read up on galvanic corrosion and the differences in tensile strength of stainless steel bolts compared to your original steel ones. Pay careful attention to locations that do require a specific tensile strength. I haven't looked at the bolt kits you linked to recently but have done my research a couple of years ago and will not be using a single stainless steel bolt on my car. Thanks George. Will definitely be using the correct grade bolts for the mechanical components as they're designed to be torque'd to spec, however it seems that these SS fittings aren't even suitable for simplest of fixtures. Will probably purchase zinc plated fittings as I go along. Quote
George Posted December 12, 2016 Posted December 12, 2016 A good place to start is an auto bolt and nut kit from eBay. Something like this: http://www.ebay.com.au/itm/AUTO-NUT-BOLT-KIT-250pc-SEM-SCREWS-PANELBEATING-BODY-REPAIR-JIS-SPEC-ARB-TJM-/222167126855 Quote
Dionysus Posted December 12, 2016 Posted December 12, 2016 Seller also has this kit.. http://www.ebay.com.au/itm/222136671259?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote
aircobra Posted January 16, 2017 Posted January 16, 2017 i got a full set, about to put it on. seems good to me. gotta use with a special anti-gall compound, which are all well documented. they don't ship any suspension bolts though Quote
geoffdy Posted January 18, 2017 Posted January 18, 2017 I got mine on ebay also. Though I forgot the name of the seller, I can say that the bolts are ok. Quote
KatoKid Posted June 23, 2017 Posted June 23, 2017 I used this guy http://www.parts4cars.com.au/Bolts-Metric/ Bolts are correct JDM automotive with captured spring and flat washers etc. Good service too. David George 1 Quote
