Gtv240z Posted September 2, 2016 Posted September 2, 2016 (edited) Does any one need to replace 240z / 260z plastic window winder regulator rollers? if so let me know , i recently turned up some of these for someone as replacements aren't available . $25 each, $45 a pair and $65 for 3 , posted australia wide , any questions please let me know pictures contain and old one and the pin which aren't included , you get like the 2 bright white ones. Thanks Craig Edited September 2, 2016 by CraigZ Scotty_Rah and gav240z 2 Quote
Gtv240z Posted December 21, 2016 Author Posted December 21, 2016 Hi all, Just thought i would post up some pictures of a winder mechanism that received 2 new rollers, 2 new bushes and 2 new pins welded in. If any one needs one repaired just let me know , some rough pricing in previous post and extra pins or large plastic washers add $10 each to roller pricing. Thanks Scotty_Rah and gav240z 2 Quote
Scotty_Rah Posted December 22, 2016 Posted December 22, 2016 looks great Craig! looking forward to getting it back and installing it Gtv240z 1 Quote
Administrators gav240z Posted December 22, 2016 Administrators Posted December 22, 2016 Awesome, great to know this is a possibility. Gtv240z 1 Quote
d3c0y Posted December 22, 2016 Posted December 22, 2016 Hi Craig, I currently have the window regs out of my doors and i'm thinking that it would be prudent to do this while it's all apart, as i had loose rattley windows that were hard to wind up. So you need 3 per side right? Do all three usually need replacing and do you have to weld the new pins to the reg arms right? Quote
Gtv240z Posted December 25, 2016 Author Posted December 25, 2016 Hi Craig, I currently have the window regs out of my doors and i'm thinking that it would be prudent to do this while it's all apart, as i had loose rattley windows that were hard to wind up. So you need 3 per side right? Do all three usually need replacing and do you have to weld the new pins to the reg arms right? Hi, Thanks for your interest! Are your 3 rollers and larger plastic collars still intact and appear undamaged? and yes there are 3 per mechanism and would need to be welded in if replaced. If yours all appear to be fine i am not sure that replacing with new would be necessary. if your window was a bit stiff it may be because of other issues. - window felts worn out creating slop/play int the window allowing it to kick over slightly and wind up unevenly. - there is also another guide roller in the top of the door which you can buy new from the US. - the mechanism may also need general cleaning and greasing. - inside door window guides out of position... what does your mechanism look like currently? here is a post from NZ it has the another roller in one of the pics https://zclub.nz/viewtopic.php?p=20818&sid=5d62fecbc695791fdf2d1796f2e5ee19 Cheers, Craig Quote
Gtv240z Posted December 25, 2016 Author Posted December 25, 2016 https://zcardepot.com/interior/interior-panels/window-glass-roller-bumper-rh-240z-260z-280z.html the other roller in the top of the door Quote
Gtv240z Posted July 2, 2017 Author Posted July 2, 2017 Hi guys , Just BUMPing this one as i am doing a turn up on the lathe of these this week so if anyone is interested , $5 off the above prices which will be standard price from now on Thanks Quote
gilltech Posted July 2, 2017 Posted July 2, 2017 That NZ post talks about sourcing rollers at Bunnings. Certainly they have a range of replacement rollers for sliding windows, doors, screens etc. I sourced some there for my Mustang - Rolltrak was the brand IIRC. What would be useful are replacement rivet-on retainers. Quote
