EJ101 Posted June 16, 2016 Posted June 16, 2016 a handy tip I got from a mate who is a builder. If you have stainless steel that needs a good clean and polish to remove stains use WD40 and a scotch brite pad . Its best if the pad is not new and coarse or you'll end up with scratches. A well worn pad is the best. I tried it on a basin and a splashback in the kitchen. gav240z 1 Quote
Administrators gav240z Posted June 16, 2016 Administrators Posted June 16, 2016 Have you tried this on the exterior trim? I might give it a go. Quote
EJ101 Posted June 16, 2016 Author Posted June 16, 2016 Only s.s on my car is the exhaust. Best to do a test patch before committing to doing it all. I reckon it would work well on aluminum cam cover etc Quote
chris240 Posted June 17, 2016 Posted June 17, 2016 Been restoring and tinkering with old bikes for a long long time and have been using wd40 and 0000 grade steelwool..does the trick Quote
Riceburner Posted June 18, 2016 Posted June 18, 2016 I had this stuff recommended to me by an old bloke at a metal polishing business I used years ago. It's fantastic, the shine lasts a lot longer than other metal polishes and there's no residue left behind to attract any dirt/dust. There a liquid spray, liquid polish and a paste. It's not cheap but the paste works the best I think. Quote
nat0_240_chevZ Posted June 19, 2016 Posted June 19, 2016 Vinegar and bicarb soda....... Or otherwise use the mobile electropolisher units, use phosphoric acid and dc-neg to bring up to really shiny but not a quite a mirror finish.... Quote
blu260z Posted June 20, 2016 Posted June 20, 2016 WD40 is good for making stainless look great BUT!!!! It leaves a oily film on whatever you spray it on and that means dirt and dust sticks to it. Quote
geoffdy Posted January 19, 2017 Posted January 19, 2017 I tried the wd40 with good results, though a bit messy because of the greasy/oily residue. Quote
Enzo Posted January 19, 2017 Posted January 19, 2017 I had a set of golf clubs that I had put away damp and ended up with surface rust on the shafts. I used 0000 steel wool with silicone to polish. Silicone dries and leaves a protective coat. I'm still using the same clubs and just wipe them with a silicone coated rag after each use. Quote
