jacksonchai Posted April 1, 2016 Posted April 1, 2016 Hey anyone have a 260z 5 speed manual gearbox for sale? I'm live in sydney, willing to pay for postage if needed. Cheers Jackson Quote
gilltech Posted April 2, 2016 Posted April 2, 2016 Maybe try dat2kman, another forum member here in Brisbane, he's handled & repaired a number of gearboxes over the years. Failing a 260Z box there are boxes from 280ZXs & other Nissan Datsuns that also fit, slight differences in ratios here & there, do a search on this forum as there have been several threads on that very topic. Quote
Moderators PB260Z Posted April 2, 2016 Moderators Posted April 2, 2016 Hi, Have a read through this thread, plenty of good info. http://www.viczcar.com/forum/topic/1966-what-gearboxs-fit/page-1?do=findComment&comment=16772 I have a 280ZX box in my car (behind a L28E) and it is ok, 1st is a little short but the rest is good. Cheers PB Quote
dat2kman Posted April 2, 2016 Posted April 2, 2016 Are you looking for 260 box specifically for the closer ratio gearset? Or , just a replacement box? If former, then yes, the 2.9 first gear 260 box is good, and are well worth the money to rebuild, provided teeth arent ruined. If its the latter, just use any B type box from any of the larger older Datsuns, mostly they'll be 3.3 first, some ZX's and utes, had 3.5 first. What is wrong/issue with your box now? Interested in a neat proper Close Ratio box? jacksonchai 1 Quote
jacksonchai Posted April 2, 2016 Author Posted April 2, 2016 Hey dat2kman. My 240z is auto so i want to convert it to 5speed manual. What do you think is best for me? Quote
gilltech Posted April 2, 2016 Posted April 2, 2016 Just wondering why you advertised for a 260Z box when you have a 240? Not that there's much difference, and dat2kman has all the info on that. Quote
dat2kman Posted April 3, 2016 Posted April 3, 2016 Ah! Ok then, You can se pretty mch any f the std type 71B bxes. Yes, a 260 box, s a sweeter bx, due to the ratios. Hard to find though! Start hunting for a Bluebrd /Skyline/ZX/24K box, but you'll also need a manal flywheel, pedal assy and other bits. You can use a L20B flywheel with its corresponding clutch plate and cover. Quote
Andrew_L26 Posted April 3, 2016 Posted April 3, 2016 It also depends on what diff you have and if you're wanting to change it. I believe that the 280zx boxes are more suited to the auto diffs however I'm still not sure how it all works (Just that my auto diff is fantastic with a 280zx box) Quote
280zUSA Posted June 7, 2016 Posted June 7, 2016 I have a 2.9 close ratio 5 speed fully rebuilt with short shift conversion for sale if you are interested jacksonchai 1 Quote
mossy Posted June 7, 2016 Posted June 7, 2016 I have a 2.9 close ratio 5 speed fully rebuilt with short shift conversion for sale if you are interested Should sell quick if you list it for sale gav240z 1 Quote
jacksonchai Posted June 8, 2016 Author Posted June 8, 2016 I have a 2.9 close ratio 5 speed fully rebuilt with short shift conversion for sale if you are interestedPm sent Quote
