Well I have a nice set of leather covers fitted to a set of seats from a 1976 2+2 and then went to fit them to my 1975 2+2.....darn but they are different.
Now am in need of a set rails or even whole seats if they are still attached....in Brisbane would be nice.
The ones I have in my photo are the wrong ones
          G'day mate, found these among'st my spare parts. They used to be in my 2+2 don't know what year tho.
                                        Yours for pstge cost plus a donation to the site.
                                                          Regards:Alan.
Those look rather different to my 260 2-seater - mine just have the vertical projecting bolts (with the plastic spacers) without those formed feet. I didn't realize the 2+2 seats are different, not to mention the floor frame.
Thanks Alan, could you just post a photo of them first so I can check they are the same. The early ones (1975) have the rail bent down on both ends (bolt on a sloped section) and the 1976 have the front sloped and the rear flat.
  G'day mate, the rear section that the bolt passes thru has a rivet that secures it to the seat rail.Think that if you ground/drilled the rivet out enabling replacement with  front units which I can grind/drill out for you from the seat rails I have. You can either weld or bolt ,or if you know some place that can re-rivet it for you if you wish to retain originality. If you want to go this way or as a temporary measure until you get the ones you desire I'm happy to help you out. Cost will be $25 donation to web site.
                                                      Regards: Alan.
  • 2 weeks later...
What do they look like? The ones you need?
Sadly I do not have any to take a photo of and as much as I look around the net I cannot find any photos of my type. I can say the photo that Alan put above are the wrong ones ^-^
They need a turned down bolt on section on both ends instead of one turned down and the other mounting on the top face of the rail on the floor...clear ::)
I was mainly asking so I could keep an eye out and let you know when my spidey sense was tingling haha.
