It's still pretty easy to buy a 280ZX distributor which is a bolt in solution
I added this to mine a couple of years back after having the zed on the dyno. The new ignition along with a bit more port and exhaust work jumped the output and smooth dyno curve of the engine considerably. As noted, easy to install and manage.
Ian
I like the Pertronix kits because the base plates of the 280ZX Items used for advance vacuum are fragile. No Issue with the stock dizzy, my other Zed runs it.
Also fitted Pertronix to a Series I 1970 Jaguar, works perfect!
Hey Scoota
Does the Pertronix kit replace the vac advance breaker plate of the standard 280zx dizzy?
Mick
Hey Scoota
Mick
I doubt if they make them for the 280ZX Distributor Mick.
They do quote for a 280c (l28, l28e), i forgot to ask when I talked to them today.
the kits are the same for the L24, L26, with a Hitachi system, to replace points with part number GH203 - cost is $132 plus GST ($145.20) plus postage.
I reckon I'll get one, because im always checking, regapping and replacing points, and I kinda wanna keep as many original parts.
I dunno how that compares to the price of getting a 280zx dizzy, and how they compare in terms of output, but meh.
attached is the pdf of makes and models.  all prices are pretty similar I think (I got quotes for my navara (z24) and corolla (4k) also - only $8 in it.  that was just the points replacement and not the coil with it - the ebay store looks like you would add ~$100
http://stores.ebay.com.au/Pertronix-Australia/Pertronix-Ignitors-/_i.html?_fsub=3437130011&_sid=777022241&_trksid=p4634.c0.m322
46864_73f9a1dd96dbf1c691064844e1e4c656888fb082.pdf
