tin Posted August 7, 2014 Posted August 7, 2014 hey there, chasing after some black door trims as i always miss out when they get put on the classifieds section. if anyone has please let me know cheers 260z door trims Quote
44014 Posted August 7, 2014 Posted August 7, 2014 240z are available new from nissan 260z are different to 240z door trims and early ones are like unicorn farts. Quote
Riceburner Posted August 7, 2014 Posted August 7, 2014 Have they started production again for the 240 door cards? Quote
Administrators gav240z Posted August 8, 2014 Administrators Posted August 8, 2014 260z are different to 240z door trims and early ones are like unicorn farts. I've seen them on Yahoo! Auctions a couple of times, cheaper than 240z ones. *Edit actually I think they were reproductions.* Have they started production again for the 240 door cards? Not sure, but you can get them for around $600 AUD before shipping before broker fees. So I'd say around $750 for a set from Japan. Good second hand ones are thin on the ground these days. I've seen about 3-4 decent sets in the last 6 years and I bought 2 of them I would sell my half broken drivers side off HS30 00150 photos here. http://www.viczcar.com/forum/index.php/topic,4189.msg155293.html#msg155293 If you think you could figure out a way to repair it? More power to you! Quote
Administrators gav240z Posted August 8, 2014 Administrators Posted August 8, 2014 Seller HappyPizza does a lot of early Z stuff. http://www.buyee.jp/item/yahoo/auction/p405736755 Another seller, similar price. http://www.buyee.jp/item/yahoo/auction/s377822944 Later '260z' style ones. http://www.buyee.jp/item/yahoo/auction/v351851057 Not cheap... Quote
Riceburner Posted August 8, 2014 Posted August 8, 2014 When I purchased mine 3-4yrs ago they had to check with Nissan in Japan who were only showing one set left. In saying that I bought NLA gnose covers new from japan even though Nissan said they don't exist anymore. I'm sure sellers have stock piles of certain products. Quote
d3c0y Posted August 8, 2014 Posted August 8, 2014 So does the OP want a 260Z trim or a 240Z trim? Quote
tin Posted August 8, 2014 Author Posted August 8, 2014 decoy - i was always under the impression that very early 260z (2seater) door trims were the same as 240z?? if someone could clarify for me, only cause my doors are the same as a 240 gav - sent pm Quote
44014 Posted August 8, 2014 Posted August 8, 2014 decoy - i was always under the impression that very early 260z (2seater) door trims were the same as 240z?? if someone could clarify for me, only cause my doors are the same as a 240 gav - sent pm Nah mate , I have 2 74 260z's and they both have the 260z long armrest/handle and have the little fake wood strip. 240 are built for the grab strap and little arm rest. Quote
NZeder Posted August 9, 2014 Posted August 9, 2014 Early 260z doors are different with the window crank handle about 30mm further forwards vs 240z stuff and that is even before you look at the styling differences aka arm rest pull vs separate arm rest and pull on a 240z. Quote
tin Posted August 9, 2014 Author Posted August 9, 2014 Nah mate , I have 2 74 260z's and they both have the 260z long armrest/handle and have the little fake wood strip. 240 are built for the grab strap and little arm rest. Early 260z doors are different with the window crank handle about 30mm further forwards vs 240z stuff and that is even before you look at the styling differences aka arm rest pull vs separate arm rest and pull on a 240z. ok thanks everyone for clearing that up for me. then im chasing after 260z 2 seater door trims Quote
NZeder Posted August 9, 2014 Posted August 9, 2014 And later 260z 2 seater trim is different again as the door lock is further forward vs earlier year versions. Quote
Administrators gav240z Posted August 11, 2014 Administrators Posted August 11, 2014 Not sure if this is early RS30 or later RS30 2 seater trim? http://www.buyee.jp/item/yahoo/auction/m124593681 But currently a good price if you're not after 'mint' door cards. Quote
