Riceburner Posted July 25, 2014 Posted July 25, 2014 I have for sale on of my LD28 Crankshafts. Freshly back from crankshaft rebuilders with a crack test and full check done. It has check card and report attached. All standard size mains and big ends etc. There is .004" bend in the crank, it can be straightened for $100 when you get your machining done. This is a PROVEN excellent crank, checked by crankshaft rebuilders. $950 firm, pick up only. NOW $850 Cheers, Gareth. Quote
DreamZproject Posted July 25, 2014 Posted July 25, 2014 Holy S, i saw LD28 crank for sale and then saw the figure $100 mentioned, nearly pooed my pants before reading it again... Quote
Riceburner Posted August 2, 2014 Author Posted August 2, 2014 If you have a block girdle as well as cash the price can be lowered accordingly. Quote
luvemfast Posted August 28, 2014 Posted August 28, 2014 Are you after a girdle Gareth? Think I have one in my garage, surplus to my needs. Quote
Riceburner Posted August 28, 2014 Author Posted August 28, 2014 Will it clear the LD crank? There's also another one I'm looking at, I'll start another thread. Quote
Bert Posted September 29, 2014 Posted September 29, 2014 Do you still have your ld28 crankshaft for sale? Quote
Riceburner Posted September 30, 2014 Author Posted September 30, 2014 Do you still have your ld28 crankshaft for sale? Yes still for sale Bert. Quote
Arnold Mendoza Posted October 21, 2014 Posted October 21, 2014 Hi Gareth, Is this still available? Thanks! Quote
Riceburner Posted October 21, 2014 Author Posted October 21, 2014 Yes, still for sale. Originally I wasn't keen to ship it as I have no control on the condition it arrives in, but I'll give it a go. As far as protecting it to ship I had thought about bubble wrapping it and then putting it in some 100mm or so PVC tube. Sure that would keep it safe? Quote
24TZ Posted October 22, 2014 Posted October 22, 2014 That's a great idea mate, I'm thinking of getting a crank shipped aswell and that's perfect way to send it. Cheers and good luck with your sale Quote
Administrators gav240z Posted October 22, 2014 Administrators Posted October 22, 2014 Or go to Bunnings and get off cuts of chip board cut to the size and shape of the crank and then use nails to create a small box for it. Shouldn't be very expensive and that was how mine was shipped with bubble wrap for added protection. Quote
Moderators PB260Z Posted October 22, 2014 Moderators Posted October 22, 2014 PVC tube would work well - and for packing use expanding foam, if the crank is dirty, oily or greasy wrap in plastic before adding the foam. The foam will stop it moving around and can be dissolved in petrol or similar leaving no residue. Cheers PB Quote
Riceburner Posted December 15, 2014 Author Posted December 15, 2014 No not yet. I was starting to think I'll keep it as a spare, or at least until the other crank is finished in case anything goes wrong with it. PM if your interested, I can get a price to post it. Quote
Triptych Posted December 15, 2014 Posted December 15, 2014 Alright. I might start putting some money aside just incase you decide to sell it in a month or 2. I have been trying to work out if I want to stroke my L28T as I have to do something about new pistons and rods anyway when I rebuild it so may as well go all out. Quote
