SOLD!
Reconditioned 260Z Close Ratio 5-speed gearbox.
Rebuilt buy myself under the guidance of Datsun specialist Les Collins at his workshop.
Specs are:
* 260Z Housings, Water-Jet blasted inside & out. All other components cleaned.
* 260Z Gear-set, 1st: 2.906, 2nd: 1.902, 3rd: 1.311, 4th: 1:1, 5th: 0.864, Rev: 3.382. Gears were cleaned & inspected for wear. All pronounced serviceable. Steel selector forks.
* Converted to brass Warner style syncros. New syncro rings on 2nd & 3rd. Back-cut dog rings on 2nd & 3rd gears. Clearances checked.
* All new sealed roller bearings fitted. Needle roller bearings were pronounced serviceable.
* Double Lock-Nuts on mainshaft.
* Short shifter conversion fitted with new Billet shifter, bushes & cup.
NOT INCLUDED in this sale is a clutch fork, clutch bearing carrier or gearbox mount - reuse your old ones.
Fork & bearing carrier are available at extra cost.
I was hoping it would stay on the market a couple of months, give me a chance to get some coins together.
Dreamin' - things happen quicker than that around here  ;)
Hit up PMC he can build you the same thing and needs the work!
It did not sell on this forum!
It went via a dirt rally forum, those guys know value when it comes by.
I've got one, it's an Albins though, closer ratios, could be persuaded to let it go, like everything else!
