I have a few parts that I have been keeping but unfortunately my new shed is a big downgrade so parts have to go.
Due to moving I would prefer to sell parts locally. My place is in Eastwood Sydney and I can be contacted on zero four three four three one four eight three seven.
Parts
Pair of 240z inspection lids $40 each or $70 for both
240z drivers guard with factory hole for fender mirror.( dont have mirrors)
Good condition no rust repair in the top like the other 5 sets I have owned. $250
Quarter panels
Drivers side needs work rear corner and could only be used with flares $150
Passengers side needs front section below crease line some bog at rear $150
Passengers side has bog flare and been hit from behind most of the rear corner is out of shape or missing. Only really useable for repair sections  $50
240z Hatch couple of small holes where spoiler has been fitted other wise good $200
260z two seater front and rear bumpers yet to check condition painter black with brackets
Have other external parts/panels cant think of everthing now, let me know if your after something. Will sell multiple items for less.
Is it an early 240z hatch with vents or later 1?
Do you have a 240z drivers door? Or a good bonnet?
Might give you a call to see what's what ;)
Hatch is the later style without the vent's.
Have a bonnet with the common light hit in the middle which has bent down a bit with hard to fix dent.
Probably not too much use.
No spare door's
The add was a rush job no thought went in to the title.
Title very (intentionally) misleading. I thought (Everybody else probably did too) a 240Z was for sale.
Sook harder
2 seated ones should fit I think 2+2 also can fit but are a little wide so would need trimming down.
To clarify the front is the same but the rear bumper is wider.
240Z rear bumpers fit on 260 2 seaters but mounts are different. +2 rear bumpers are wider and side parts are longer too. Totaly different.
Hi there. I think the number you posted is wrong. Tried calling. Need a couple of bits off you ASAP.
Please contact me via pm or 0432 860 99seven
