  1. Past hour
  2. Will add this one to my list: https://bringatrailer.com/listing/1967-datsun-411-sss-wagon/
  3. Yesterday
  4. Last week
  5. AI can be hit and miss. I asked AI the length of the Z car bonnet, it said 2.4m. Ah, that’s the car length. Now it says 1.6m. I think it’s closer to 1.4. I’d assume you have some packages of hardware bolts, just try some and see what it is. Or take the handle to Bunnings and find some loose bolts to test. Actually, on mine, it looked like a pin was used, so AI is wrong again about it being a screw. Some probably are, but not all, I suspect.
  6. not m4 as it says here? What’s the thread pitch?
  7. Yeah neither of my shifters has them. I’d buy new anyway if I was you….
  8. Thanks! Despite people saying the bumper mounts were too high, the pics of rotisseries did suggest they were actually too low!
  9. Convert it to manual transmission, and you wont have to worry about the screws (you can buy them from your local bolt shop - M6 counter sunk)
  10. Centre of balance point is 75mm above the bumper centre-line. It's very easy to work out. The F&R bumper mounts are plenty strong enough to support a bare Z shell. FWIW we have two rotisseries that we made from engines stands with the centre mast raised by 400mm. Don't over think it - they are easy to build.
  11. Hi, looking for a rotisserie, ideally 2nd hand (in Melb / Vic), but also tempted to build. Some people have used two engine stands, but they're too low so need modifying. They do need to be connected together. Trick will be getting the correct pivot height, so its easy to turn and will stay in any angle without excessive locking. Two people have both said the bumper mounts are too high and the car is bottom heavy. But if that changes between US and AUS, or 240-260-280 I'm not sure. Commercial items: This one is said to rotate very easily: was sold on this forum a few years ago (Peter Allen) DIY: DIY with adjustable point of rotation: This person used two vertical pipes that are on each end are held by u-bolts through the engine stand. So the car can be raised or lowered to get it to the proper balance point. (car is sideways in the pic) They say "the car is very neutral and can easily be spun with one hand. You can use the pin on the engine stand to hold the car in any orientation. When I go to set it down on it's wheels, I can loosen the u-bolts and slide it down until it is close to the ground". So, anyone have one for sale? Or any experience building one? I like the idea of one that can be adjusted to find the C of G. Cheers, Richard
  12. I'll have a look tomorrow (aren't at the location of my car until then). I know I have two auto shifters, and I going to convert to a manual. But you know what they look like.. A nut and bolt store might be the go. Mine could be quite rusty..
  13. Surely someone who has done a manual conversion has these!? If anyone has these screws, please message me! Sth East Melbourne location.
  14. The painted suspension going back in with new bushes:
  15. Finally got some paint on 905 red is very red? Found some braided hose (slightly lighter braiding than original but better than straight rubber) and used 2 strands of copper wire to shape. Looks ok but wire might be too soft? Printed a hinge for tool box needs a bit more work hinge too stiff
  16. Earlier
  17. Assembly could now begin. All the plated parts were organized, and any sub-assemblies were put together. The fuel and brake hard lines were installed in the chassis, followed by the brake booster, brake and clutch M/C's, and pedal box. The firewall mat was supplied by ZCarDepot to suit a RHD Z, but it needed much modifying to fit. Very disappointing and I don't recommended it.
  18. With Daniel wanting a lower Z, we needed to have the strut tubes shortened so we could maintain effective bump travel. I took some measurements, then sent the bare struts off to be shortened and the gland nut threads recut. Being that the struts are 55mm (with the long rear tube), the rear needed a spacer in the bottom with a spigot to engage the bottom of the Koni insert to pack it up and keep it central, so a pair were machined up out of aluminum. We then assembled the struts with new Lovells lowering springs and their rebuilt braking components so we can fit the struts to the 260Z and get it rolling on it's wheels.
  19. https://auctions.chicaneauctions.com.au/auction/august-2026-collector-performance-rare-car-auction-30/item/1973-datsun-240z-376/
  20. Nismo 10th anniversary steering wheel, mint condition, $1150.
  21. 45mm Steel Hub Dust Cap Zinc Plated - 2PC - Superior Trailer Parts 45mm outer, same as z front hub bearing caps..... massive price difference from original and ill be powder coating these black .... not sure if anyone has tried this before?
  22. Refer to the donk in the engine bar: and maybe the flares too haha
  23. I need the following items, does anybody have these or know where to buy without freight costing $100 for an envelope!
  24. https://www.carsales.com.au/cars/details/1969-datsun-1600-manual/OAG-AD-24642820/ or here https://autodynasty.com.au/buy/1969-nissan-bluebird-/Q2QGzaynhcol8AVATQrdqA Another ripper!
  25. Would be interesting to start a discussion thread mods you wish previous owners HADN'T made!
  26. Go to this youtube video: Go to approx. 1.0 minutes. This is LHD VIN#16 which was one of the first cars sold to the general public in the USA. The car was originally gold and was repainted white in the early 1970's. The stickers/decals were applied to the time of the repaint. Its 1970's cool.
  27. I love originality, but for me... Upgraded Brakes Fuel injection and modern ECU Air Con (for hot summer days in Australia) Upgraded wiper and heater / fan motor. Makes the car infinitely more usable all year around.
  28. Another local option is Coilovers by Supafatto. You can find him on Facebook or below. https://www.pitloon.com/businesses/supafatto
  29. $3k-$4k buy the time it's all done. We are in the Latrobe Valley.
