  1. Last week
  2. I doubt you'll find a NOS RH door mirror here. I haven't seen one in decades. FWIW I fit the LH mirror to the RH door on Zeds here and it works perfectly well. However if you fit a LH mirror to a LH door and try to use it fro the RH seat, you can't get enough articulation out of the pivot to see down the side of the car. I suspect if you fitted a RH mirror to your RH door, you would have a similar vision issue from the LH seat...
  3. Not sure what this group can do in terms of VF Commodore advice? We are focused on Nissan S30Z series.
  4. Hey guys so Vf commodore its currently regoed as v6 I have found somebody thats willing to give me a roadworthy with v8 engine numbers that I bought a v8 engine to do the swap now would vic roads catch on to it an make me bring the car or would the roadworthy certificate be ok an just pay everything online an move on or what should I do has anybody done that
  5. Earlier
  6. Thanks, it looks like their account was compromised. I've send them a PM and asked them to change passwords. Edited original post for now, will remove soon.
  7. G'day, Reviving an old thread here, I'm in the market for an oscillator. I have a rally clock, which I think is functional. I've found the EZ-A product on the JDM car parts website in the USA, however with the current exchange rate, its $700 AUD before shipping. Does anyone know of a cheaper way of doing it like posted earlier? Or are they still available? Thanks very much in advance GrandpaZ
  8. Hello. Firstly, I'm a yank. I know I know, but we'd get along if you met me. I'm looking for a factory oem door mirror from a 240z. The part number is 96302-E8800, but I've yet to find any NOS anywhere so I figured I'd try here. I'm sure it's a bit more hassle to ship to the US, but I'd be happy to pay for the trouble. Here's a pic of my car with the mirror I'm looking to match from a right hand model. Thanks so much!
  9. OK, maybe time for an update. Purchased a second hand SCA sandblasting booth. My DIY effort at a booth is bigger, but the SCA one works. An important aspect. 😎 (Though I do think DIY special tools are one of the fun parts of auto mechanics, this is I think my first failure…?). Cleaned all rear suspension and diff, which is from an auto model and is 3.5 by my calculation. However, rather than buy a 3.9 for my manual conversion, I think I’m going to replace the 195/70/14 tyres with 185/60/14. And then the ratio after the gearbox is the same as a normal manual. However, interested in any significant negative aspects of that maybe I’ve missed! Stripped down both doors, and realised there’s some seals here I don’t have, and also need the handles to open the doors from the inside. Didn’t actually find much more rust than I didn’t know about, don’t believe the skins need to come off. Wick Humble’s book was very helpful for removing the glass, I remember this being a b*tch of a job on the 1600 and N13 Nissan Pulsar. It did take about 30 min for the first door to get the glass out because I didn’t understand what the internals really looked like. Second door was about 3 min. It’s actually a very easy task. I did find once you have removed the two bolts holding the front guide for the glass in place, tipping the entire door 90 degrees on to its front edge so the glass falls forward helped a lot. Then pulling the rear edge of the glass up and rotating out the gap. And, we spent a bit of time estimating the budget for the restoration, adding up all the costs of parts needed to be purchased, labor I’m likely to require, and tools. It’s at about $30k already…. Cheers!
  10. Hello, I also need the diagram for a 1976 260z, could you share it with me? I would be very grateful for your help.
  11. Well, some good progress: Front suspension, steering rack, cross member all removed. Rear suspension, diff, hand brake out. (Diff+remaining suspension all came out very easy, guessed the right spot for the jack, which was good because Wick Humble says have a strong helper and all I have is a Cavoodle and a Maltese Shih Tzu, neither with opposing thumbs). Just fuel lines, rear wheel brake lines to remove, simple but pesky grime covered bolts and screws. Think I'll take it too Northern Soda blast in Ringwood for blasting and priming (2k PPG urethane epoxy). Going to visit Saturday and have them blast the hatch first to test them out. Also did a bit of unpicking spot welds, using a combination of 3/8th in drill bit (possibly bigger than needed 🤔) and hand chisel (and need to get an pneumatic chisel (keep forgetting I now own a compressor... 🤷😆). Oh. And also bought a second hand rotisserie. Wife approved, but maybe there was a misunderstanding?? 🤔🤔🤔😆Paid $900 for 1800kg capacity. Could buy a 900kg item brand new for $880, but expect to transport on the rotisserie because the blaster doesn't have one, so decided the extra strength was worth $20.
  12. I ran the group buys with the parts and panels supplied by Resurrected Classics in the USA as they were the only supplier at the time. It ended up being an expensive process. The prices listed here https://allmusclecarparts.com.au/datsun/240-260z.html are much cheaper. I'm not sure how much you'd save by importing them yourself, but best of luck.
  13. Yep. Just as I remember it. Get the whole thing media blasted (by someone whos knows what they are doing) and locked up in Epoxy. Then start the repairs.
  14. And here's the pictures of the remaining repairs:
  15. Ok, some pictures of where we're starting from. This was @Linton's second car, that he'd started before his tragic accident. I realise now how much work he'd done. The roof has the worst surface rust, though a few spots on the bonnet might be worse. I think the roof is salvageable, based on no experience but just wishful thinking! 😎 Linton fixed some front end damage to both guards. Fitted a new radiator support panel. Made and installed new rust cuts under the battery, and to the LH side of the firewall. Repaired rust around the top of both taillights and the "slam" panel. (I'd call it the hatch sill?) He also did some repairs to the LH chassis rail, but unlike the other repairs which were highly documented I don't have any pictures of that apart from the very initial condition. So I'm not really sure how deep that repair went. Still to do: LH sill and bottom of the A pillar. RH bottom of the A pillar. RH rear of the door, and the RH dog leg. RH front of the door. Two spots on the LH door where I think a chrome trim strip was attached. Dodgy fibreglass repair to correct on the bottom of the LH guard. And the bottom of the support panel inside it no longer exists. Plus what I haven't found yet. I don't think the radiator support panel is parallel with the firewall. Not sure how or why, but we might have to install the bonnet to see what the alignment is actually like. So, that's the fun that awaits. Not sure what we can do ourselves, mig welding sheet metal is new. Ideally we'd practise on offcuts first, and non visible parts of the car. But next: media blast the whole thing and 2k epoxy is the guidance we've received. Cheers, Richard
  16. NickF
    door alignment
  17. i think i saw some 'group buys' on the forum in the past would people want any of the panels to share freight
  18. saw that. appears to be 300%+ ,markup over the factory price. must be the shipping
  19. C.A.R.
    door alignment
  20. If you want china panels, you can get them here in Australia: https://allmusclecarparts.com.au/datsun/240-260z.html Do they fit? Yes. Are they OEM quality? No.
  21. Stuff has started appearing on Aliexpress. Has anyone bought any of them and does it fit?
  22. NickF
    door alignment
  23. Measure the thickness of the original panel, then replicate in the appropriate thickness steel. 0.7mm & 0.95mm cold-rolled are both available from steel merchants.
  24. Back from a break so back on this topic Need to make a couple of patch panels , presumably 1 mm and 1.2 are the way to go? When I measured up some of the parts, they seemed to be only0.7 to 0.8 though Presumably these are the standard sizes in Oz Cold Rolled Steel Sheet - Melsteel
  25. Did you sort the dimensions? are the plans incorrect?
  26. BOT alert. Gavin or admin please have a look.
  27. https://redacted.com Find a girl who shares your desires [url=https://#] Real Girls. Real Nights. [/url]
