AK
Everything posted by AK
  1. Re- Fresh on the Tail Lights I did this while the car was getting the coat of Sublime Lime at the spray painters. I went away from the stock silver colour for the outer assembly and went to satin black, which turned out great good contrast against the bright green and it made the tail lights pop – stand out . I polished up what was left of the chrome, pulled the whole assembly apart, polished the coloured lenses with a Maguires headlight polish for plastics . If you are going to hand spray parts with spray cans the UPOL Spray Cans are really good the size and power of the spray pattern is like a small professional gun and much better than anything else by a long stretch. The original white silicon/sealant that held the indicator and stop light lenses to the backing plate/lens assembly was really hard to get out.I used a thin vibrating tool attachment that was the only thing that really worked and it was a long process. I resprayed the inside backing lens in a metallic silver after a plastic primer was used first., Silicone the lenses back into place, there are some small round hoops spaced around the backing of the lens assembly and these are used to hold the chrome surrounds in place screwing through from the back . These small hoops in my case where fractured and thin so I got a super strong plastic glue and glued in the right size metal washers , with ample amounts of glue to reinforced the areas and then finish them up with a small Dremil attachment to sculpt back to shape that didn’t interfere with fitment of the parts. Anyway long fiddly process but in the case of 260 2+2 there are not may parts around here and I like the look of the 260 2+2 lights more than the other models so the end result was great. LED Light assembly’s with be fitted once I have all the wiring back in place this with give brighter more intense colour for the Orange and Rred and the White reverse lights
  2. More pics of starting to put the suspension back and some more pics of the body prep before the professional spray job, fitted some adjustable camber adjustment to the pivot locations on front and rear so hopefully when it lowered that a proper set up can be achieved. Rear Axel Stubs refurbished and painted with KBS paint Fitting the Bushings for adjustable camber I broke a vice in this process fun and games and a lot more swearing it a second language sweararific. Which way does the swing arm fit - this way I had to make up plate as the diff assembly was still LCR getting done and I needed to get her on wheels so it could get sprayed . Sealing the car with black primer after the high-fill all you need Fitted the MCA Suspension - Mean AS!! - The adjustment caps where to high so for us Zeders you have to remove them put in the glove box and put back on to do the adjustment not to hard to do no big deal the car is super low now - you dont run the rubber mounting blocks at all with these shocks in and it makes a huge difference to the ride height. Can wait to try out seems like not body roll at all, I push on the cars roof line sideways with max force and does not move at all. Some more pic of paint work before the Sublime Lime goes on
  3. Back again Check out the All U Need Can Some more pics of the All U Need applied and then block sanded back to a 320 grit paper then Black Primer to seal it in a few places where the All U Need was thinned out from the blocking process of taking out the high and lows.
  4. OK it been a while since my last post and to say the least - I have been busy – productive that's another discussion where you dont want to get the women involved if you know what I mean. Anyway what I have done since the last post : Finished the body work (say good bye to 100s of hours of painstaking work) · Got the bumpers back from being reconditioned · Picked up the incredible engine Re Build from Les Collins Racing · Picked up Re Built Gear Box from Les Collins Racing · Got the dif back from Les Collins Racing · Did the roof lining dark grey swede leather ( I did that my self) · Had the rear hatch and a new front Window refitted with new rubbers · Put in Dashboard · Put all the Suspension back in · Put the steering back in · Put the tail lights in · Bonnet back on · Fender mount mirrors in place · Some of the brakelines · Put the engine in · Put the Exhaust back on Combined this activity withthe selling the house and preperations for moving to the Sunshine Coast in Queensland – What can I say I am certifiably crazy Well it was very satisfying to finish the body work to a level that even the panel shop was ok with, in his professional opinion better than a lot of other panel shops would do. I have to say doing the body work was hard physically and it took about 5 times longer than expected and the 150 Square meter shed looked like a cocaine bunker by the time I finished white powder every where. No wonder it cost serious coin to get done properly I used a product called All U Need as spray filler for the final push to finish the body work off and it was really good, it got out the pinholes transition problems with different fill heights and to say it drys super hard with virtually no shrinkage would be absolutely correct. See some pictures below of the final push to finish all the body work - the every part of the car filled and block sanded to hopefully a near perfect finish. The front indicator corners and the stone tray where in poor shape thin and beaten up by the passage of time, these where massaged back into shape and Ii applied some fiber reinforced filler on the back, this gave the strength to hold shape better - I did the same with the grill under the windscreen. The Sublime Lime turned out awesome Finished the body work this was a massive undertaking for a newbie got say it physical taxing and the time it took was probably about 5 times longer than I thought it would take but if there was a
  5. SHICER! What a collection very very mint! That some serious passion for the car.
  6. Hi Patch - Owe ya beer or 3 awesome price booked in Supa Tow - Cheers AK
  7. Thanks for the suggestions - Greatly appreciated!
  8. Hi Guys My car RESTO completion and relocation to QLD Sunshine Coast are rapidly approaching, car is not going to derivable unless I get the help of Chip Foose Magic Minions, anyway I will have to go with the back up plan of Tilt Tray transport from Melbourne to Sunshine Coast - expensive options but I dont have may other choices from what I understand with car that not going or not Road Worthy. My other car is not up to the Towing Challenge. Anyway from what the Towing guy has said if I can find some one who needs Transport of Car from QLD (Sunshine Coast or Below somewhere) back to Melbourne/Vic somewhere it may reduce the price a little for both parties so a CALL OUT here for any interested parties that want to transport a car early DEC will be the time frame 1st week most likely. Cheers AK
  9. I Polished my Jelly Beans Mags to mirror shine - Gloss black on the inside and they look mean as - I think generally we are getting to the stage that large wheels with huge openings are almost the norm and have become almost boring - so these old school wheels are starting to get a lot more curb appeal mine are 225 at the back 215 at the front - I like them - I was going to change at one point to ROTA RKR style spoke but I dont think they look much better now and if I went that way it would be diameter and width up grade as well - the Jelly Bean are certainly very strong strong. Cheers AK
  10. Hi Guys - it sold today - thanks for your interest Cheers AK
  11. Hi Guys I have finished with my Rotisserie so it is up for sale I have only had it 12 months and its been through one build, it did the job easy and i will be selling it with the brackets and fittings I used to attache it to bumper bar bolting locations. It is located in eastern Vic about 40min from the CBD Great buy for some one ready to go intoor or prepairing for a full resto at . Manufacturers blurb below and some pics. When mounted I could hop inside the car while the body was mounted to the Rotisserie and you could actually spin the car quiet fast when standing on the side of unit as the balance piont was quiet good and the strength of the unit was great to. First in - best spun. $750.00 AK Tomahawk USA Designed Moto Max Truck Boat Vehicle Car Rotisserie Repair Restoration 4500LB/ 2040KG TWIN 8 TON RAMS, 178CM - 680CM MAX LENGTH $2499.00 RRP Second Hand Price $750.00 Description When you are lifting a heavy car, you want to be sure you can trust your equipment. You want something built tough, reliable, and dependable. That's why the MotoMax 4500LB Car Rotisserie is the ideal choice. Constructed from LifeTime Quality 3.00mm Gauge Steel, the MotoMax 4500LB is the perfect choice for the Commercial BodyShop or the Home Restorator. Featuring Twin 8T Hydraulic Rams, the MotoMax 4500LB offers 360 Degree Rotation with Twin Spring Loaded Positioning Pins allowing for Easy Access to Cut, Sand and Weld you Car or Boat. Built tough, the MotoMax 4500LB comes with a 3 piece telescopic arm that extends from 178cm - 680cm. Height adjustment can be made using the Twin 8T Rams, or for Smaller adjustments the Twin Handles can be used to set the centre of gravity. Fitted with 4 x 8" Injected Moulded Wheels and 2 x Smaller 3" Castors , the MotoMax 4500LB offers smooth manoeuvrability once loaded. Be quick. At a fraction of the RRP, you can't pass up this fantastic offer. Specifications Features · Tomahawk USA 4500LB/ 2040KG Car Rotisserie · USA Design · Twin 8T Hydraulic Rams · 680CM Max Adjustable Length · Twin Height Adjustment Handles · Twin Lock Pins · 4 x 8" Injected Moulded Wheels · 2 x 3 " Castors · 3.0mm Gauge Lifetime Quality Steel · Tomahawk USA Nothing Comes Close PRODUCT · Capacity: · 4500LB · Hydraulic Rams: · 2 · Ramming Capacity: · 8 Ton each · Adjustable Length: · 178cm - 680cm · Adjustable Width: · 39cm- 105cm · Adjustable Height: · 30cm - 119cm · Twin Spring Loaded Pins: · Yes · Twin Height Adjusting Handles: · Yes · Steel Gauge: · 3.0mm · Large Wheels: · 4 x 8" Injected Moulded · Small Wheels: · 2 x 3" Castors Dimensions & Weight · Packing Size: · 155*75*40cm · GW/ Nett Weight: · 215/ 190Kg
  12. Hi Linton I had not thought about too much - I was going to give that job to a professional interior guy. I was going to glue a bracket in place with with some chassis body work glue make this pretty beefy as this would also be a central point to hold up the roof lining from, I have a 16 LED square interior light but it looks a little big so I may have to get a smaller unit and I starting think round or oval would be nicer match the car - that as much as I had thought about it, but i was also considering a roof counsel similar to modern cars integrated into the roof lining that has lights and sunglasser holder but that may be just a pipe dream and may look to out of place in the car - I have lots of ideas for the interior in general I want something upper class plush and expensive looking with highlights in carbon ect something Zonda like would be the ultimate but very expensive and time consuming - but time and money and motivation may have me just keep it stock as well. Did I say I had not though about it too much - God help me. AK
  13. The sunroof delete Sun Roof Delete is always a topic of much discussion of how best to approach?? I mentioned my sunroof delete plan earlier in the build / reco - I will go into some more detail now. I can not say if this is the best way but is one way to do it - end result was pretty good and very strong - stronger than a standard roof easily. It took some serious hours to do this may even 100 hours - crazy amount of dicking around the principles of what I done where sound I think the execution was good for a first timer - but some one with more experience would nailed it and done in a 3rd of the time. This sunroof delete is more for the drop-down and slide back solid metal variety - but the principles could be used for any sunroof. 1. use the blank from original drop down and slide back sunroof - (removed all of the existing slide back sunroof without damaging the slide back blank is important as you will need this piece in good condition.) 2. pull out the internal frame edging around the sunroof blank - this was held in with a folded into a lip around the outer edge of the sunroof, to put is simply use these parts to make shelf for the sunroof blank to sit on at the correct level while welding into place - I saw this with my newbie welding skills as one of the hardest things to do besides trying to control heat warping from welding. Also framing the edge of the hole would make it much stronger and give more metal to weld too for more strength and better thermal control. 3. The existing frame work in slide back sunroof blank was relatively easy to pull out and it had the matching arcs to match the roof line so far the plan was working - I you had to make these right angle shaped arcs it would be hard to do it correctly - but you could also use flat pieces of steel with some light bending to match the roof line. 4. Drill holes through these frame work pieces and the edge of the the existing roof hole and bolt the metal frame pieces in place to create a shelf at the right height for the sunroof blank to sit in - once bolted in place start to spot weld this edging frame in place - note I used magnetic cooper plates and air compressor to blast the weld area after each spot weld to control heat saturation very lengthy and painful process 5. Pull out the bolts and nuts holding the frame in place and the weld in the bolt holes from the bolts using cooper plates and compressor for cooling again 6. Drop in the sunroof blank see if sits right matching the existing roof line, it pretty much did, I did need to space up the blank a little with some washers to get the right height, and use lead weights I use for scuba diving to hold it down in place firmly. 7. Start the many hundreds of spot welds crossing back and forward across the sunroof until you have solid weld all the way around - How did this work? Pretty good but a painful process with moving cooper plates and the use of the compressor to cool - even know I took my time I still should of taken a little more as I still got a little warping . So do not rush this and do not start welding again in that area until it is cool enough to touch with hand minimum at least is my advise. 8. The cooper plates I used are a Eastwood product and they are available through the Aussie distributor one plate was about 15cm long and 8cm wide the other was about a 10 cent coin size with adjust angle with magnetic backing for a novice welder like my self they where money well spent as they helped with heat absorption and reduced blow through hugely. 9. I still got some warping because of heat saturation build up from moving just a little to quick - so I had to hand beat and push out carefully and gradually without pulling the whole roof line out of shape - I used some expanding vertical bars here which where designed for making removable cargo barrier in a station wagons - I got these originally from Aldi ages ago and have used them for all sorts of things, I actually shaped a dive weight to shape of the roof and used this as pushing surface when pushing up from the inside of the car. This helped about 50% but it still need a lot hammer and dolly work to get it reasonable. 10. Fill the edging of the sunroof hole after grinding back the welds carefully I used a fiberglass reinforced filler here for greater strength. 11. Then a covered the whole roof in filler and blocked back this was repeated about 5 times - such a big curved flat surface it really was hard taxing job to get it right - lots dust, lots swearing and cursing but end result was pretty great I think - we will see what it sprays up like. 12. When you do your block sanding use a block that is long and retentively wide that you can 2 hands on and use a criss cross motion keep even steady strokes over the whole surface - do this twice with 40grit the whole roof covered evenly with filler, block back once and then recover the whole roof with filler and block back a second time with 40-git again and then go to the finer grits. Do not skimp on using the the 40grit as this really cuts and shapes the filler which is what you want to set up the correct base to work with to get a good result. Also use the black guide coat between changing to different grits to see the highs and lows in your work. No short cuts here just long physical hours here. See pictures attached Note a final spray filler will be need to marry up the surface completely and fill in all of the smaller imperfections
  14. Hi Faz I just received these yes CHRISTMAS Has come early. MCA - Aussie made exotica Using your existing axle stubs/struts - build form the ground up for the z with adjust ride height May be the finest Z shocks around I purchased the X-R Series suspension $2850.00 for all 4, send up your struts and back they come - wham bam thankyou mam The varying grades of craziness depending on your bank balance. Cheers AK
  15. Hi Jeff I hired a guy who had all the gear to do it - for him it was a part time job. The cost of hiring was pretty expensive by the time you hire a big-ass compressor with the mumbo to push out the required pressure, a Kennards in the back of Dandenong was the only place that had one for hire. I researched it a lot before pulling the trigger - I think the only thing that would be better is putting the whole car in bath of Molasses. In regards to motivation - I have a tight time line December to get her all back together thats the motivation if the body can hold up. I have a small wet blasting kit that fits on to my 2500psi Karchner which is OK for small item but not would be to slow and messy (use a lot of sand) compared to the pro set up. Off to the shed Cheers AK
  16. Hi Guys Time to add some more photos not sure if I am doing this right but here we go. The next batch of photos are of the Wet Blasting or Dustless Blasting process which over all worked really well, but on the inside of the car standard sand blasting (dry) may be better? both ways I imagine are equally problematic as the blow back from going into a sealed space would be or is really bad. The wet sand also tends to build up inside the tight spaces which means you have to stop scrape it out and start again - repeat and smile:) In any case compared to normaly dry sand blasting less mess with dustless wet blasting and the water keeps the panel cool so less warping and it keeps the dust down and it can be done at your house very handy. The process of washing out the car afterwords and getting the sand out once dry is quiet time consuming and requires patients and a strong shop-vac with a lot of different attachments to get into the tight spaces air strong compressor to blow it out as well was also useful here - scraping and brushing with a stiff bursh is also required to remove the sand - this was a painful process!!! The wet blasting doesn't hurt rubber so that's very handy, you see in the pics, but it also means the tar style sound deadners have to be removed before wet blasting and seam sealer also tends to make the sand bounce off as well so lots of vibrating tool action here which very hard work. The water that is sprayed also has additive called hang tight I think which stops the panels rusting bust in any case as said earlier I used the POR 15 process on the whole car pretty much after this wet blasting so the marine clean, the Rust Blaster and then Rust Seal Paint so reasonably bullet proof process hopeful.
  17. Thanks Lurch - I will check him out
  18. Cheers I will check him out much appreciated
  19. Hi Rudy For the money KBS paints are great, I find if you put on to thick it bubbles otherwise goes on as well as the users skill level. I am not saying I am particularly skilled. I used some Rust Bullet in the hard to get places first which I think is the best product as seems to penetrate more before drying - but its hell expensive hard and difficult to source as well I found, so I used that in the nasty places first, then tried some POR 15 which was also very good but its pretty much a one time use open the can use and chuck it - it is never as good the second time around and still pretty expensive but not as hard to source. I have a BEER fridge in the Man cave and I put these paints in the fridge and helps keep them stable and stops them going off so quick once open. I dont think any of these paints give a show room finish unless you spray them and the paint sprays fine if thined with the right thinners but its pretty toxic use a good mask. I sealed the whole car with these paints inside out - expensive exercise but the stuff is really strong and should hopefully put a end to rusting - standard paints would not do much I think in the long term. But only the inside and the bottom of the car with have the KBS style paints as the finished surface - the view-able surfaces will sanded the block sanded with filler and the epoxy primed then sprayed in Acrylic is the plan.
  20. Hi Guys I starting to run out of time on my build and I are thinking I need to get a professional to lay down the paint. I think I am capable, but getting wrong would cost me time I dont have, setting up a spray booth in my shed that reassembles a cocaine factory because of the amount of white power around - this would make setting up a sterile environment challenging to say the least. I have herd that Bodycraft in Kilsyth Vic are OK Does anyone have suggestions for a painter at a reasonable price it would be just for be just for paint I have done the body work? I want to try and stay to Eastern Suburbs in Melbourne Vic area if possible Thanks in advance Cheers AK
  21. Hi Guys I have lot more pictures and some more progress I will find the time to put them on soon I hope. Thanks for engorgement Cheers AK
  22. Hi Fellow Zeders Here is my Build story. I have been very slack and not done this sooner now even more under the pump as I moving to QLD in December so I only got a couple of months to get back together - MY GOD I am doing 2-3 hours every night after work and full days on my weekends - yes the body is cracking up and the cash is evaporating quicker than a Snow Man in the Simpson Desert. Anyway here is the story - I had always wanted a z car since I was about 16years old, now in mid 40s .. didn’t take me to long??… Had a slogan actually when I was youngster ( god I am sounding old) Z power - Z domination – Z supremacy – all TRUE of course! Now I am 45, (still a kid maybe) anyway about a year ago I got the devilish little 260z 2 + 2, as luck would have it after 24years of lusting after those long/low curvaceous lines that make 99.5% of all other sports cars look well what can I say insufficient, my little Blue GEM turned up on the internet with an address no less than 5 km form my house. The unfortunate current owner was having to make a return to life back in NZ. For a new job offer. (very nice guy actually) So seeing that she was pretty straight and had limited rust that I could see and no-bog that would show up with the basic magnetic test I put in offer that wayward KIWI could not resist, being a short trip home I fired her up drove her home much to the previous owner’s dismay. ( yarrrr really going to drive it???) YEP! She was a bit thrown together but running and she looked like she had a couple of false starts in the rebuild and renew stakes, BUT she made the short trip home. I gave her a good clean for a couple of days fish oiled the whole car and then started to take rust out from around the battery tray and surrounding areas. She had just had the following done · Some re-wiring · New extractors · Urethane suspension bumper kit · New Battery · New Coil · New dash cover · New mechanical fuel pump Closer inspection when I started the tare down – some of it done a little half assed. Even know I had in my mind to postpone the rebuild, I still polished and resprayed the kidney bean five slotter classic mags to a mirror shine. On the outward facing surface and painted the inner surface and the inside walls of the kidney bean slots metallic gloss black, the rears are about 1cm wider – tough period style mags that are Aussie made no-less. The idea was to keep her in a stable condition and limit any further rusting until I was really ready to embark on a full rebuild – part of the schedule was to finish a substantial Man Cave so I would have plenty room for a full resto. Once the 150 square meter man cave with 4.5 meter ceiling was finished I started to pull her down and remove the god-dam sunroof structure get her ready to put on the rotisserie and get all the parts wet blast/ dustless blasted Getting the sound deadening out was with a heat gun and hand scrapers was nasty hand blistering experience that took many many many hours. Still got the calluses 6months later. Much later I discovered (via the awesome Vic Z Car Forum) that dry ice to make the sound deadener snap freeze and make it brittle then use a vibrating multi scrapper tool would been so much easier – (valuable lesson No.1) The sunroof was a slide back job that dropped down in to roof cavity so it looked good actually but it limited the internal head room a bit and I was sure it would just be a home to hold moisture and cause rust moving forward so I cut it out and YES it would have been a massive source of rust in the future no doubt! As I discovered in the removal process. All the seals where toast and the trim on it was also history and rust was in and around most of the structure of it. I will have to weld some reinforcing bars in and around the hole now as it feels a bit flimsy – dam should of held out for a non- sunroof car, but it will be solid hard top again! What’s next pull off every panel I can strip out what’s left including all the electrical and the engine, suspension, gearbox, ect – try not lose anything and remember where everything goes – I must be friggen certifiably crazy .!!!! Need to learn how to panel beat, and weld as well – no small task – over ambitious completely!, but want to do it all myself – my baby, my car no one is going to touch her now but me. To much to learn even with You-Tube assistance and the help of the VIC Z CAR site but we will see how it goes no rush. But its hard to hold back just want to get all finished and start to drive her again. I have contemplated every engine combo under the sun – keep on going back original L- Series options just like the genuine raw feel and look of the original atmo engine has – seeing some u-tube of stroked versions out on the track demolishing everything in its class gut wrenching spine-tingling stuff – wish it was done now and I was out frying some tyres now threading some turns in a raw tuned 70s motorcar, sure the modern cars can be faster (that’s what the facts say) and more comfortable but character and rawness an the intensity of the driving experience is watered down and unless you are going super sonic speeds there is nowhere near the same level of satisfaction – We all know this!. Classic cars are all appreciating at staggering rate with good reason. Interior was worse the outer body showing her age massively beyond saving – the spare wheel well she is also a goner! Rear lift back struts still work -what the Hell? The suspension shocks are original on the outside at least (we will see what lurks within) they are still working but would not look out of place as some relic poking out of the sand in the 1st five minutes of a Planet of the Apes Movie A picture tells a thaousnd dollars the doors where pretty good Damm Rust Sun Roof looked good but a massive cultivator of RUST Wish I had Dome tops Classic 5 Slot Kidney Beans MADE IN AUST. more rust I dreaded doing this but it had to be done - Pulling out the heater was one the harder parts there was a lot of rust in the little radiator and pipes but still working, but I had it re-cored anyway, as the idea of complicated fix later on down the track after getting everything back to new would be heart breaking. I removed the engine gearbox as one unit using a Super Cheap Engine crane , word of advice pay for adjustable angle stabilizer as You would not be able to control how the engine hangs on the crane and I would not have got it out.without it and it and it L-Brackets and the smaller chains to connect the engine to the crane in 4 locations I attached the hoist to brackets with the head bolts to 4 x head bolts after removing the rocket cover Next I bought a Rotisserie off EBay for about $1200.00 delivered it does make working on the car so much easier an if you do plan sand/wet blasting and getting access to every surface of the car it’s the only way. Got her on to the rotisserie this actually did go to plan (for once) the front was pretty straight forward the 2 horizontal struts that go off the main pivoting horizontal bar drilled 2 side holes into these matching the front bumper mounts spacing that threaded into the inside of chassis rails. For the rear mounts on the rotisserie I got 2 u-style brackets that you would secure pine posts to a cement slab super beefy heavy duty ones . Drilled holes in the base to match the rear bumper mount holes and the uprights that would go either side of the pine post I bolted to the sliding horizontal struts of the rotisserie, I had to do a little spacing with some washers – but overall it went to plan and was pretty straight forward but it did take me 2 evening’s after work to complete it. Once on the rotisserie I removed the drive line and suspension The famed rear wishbone set up with removable pivot axel was reliably a nightmare to remove I got one moving by stacking a couple of washers at a time on one side and torqueing up the end nut to slowly pull the axel through, it worked but it was very taxing one end thread and eventually it pretty much stretched the thread into oblivion but was enough to get 80% of it out and gave a lot more opportunity to get a range of penetrating oils into the axel pivot, then I could at least punch out the remainder of it with sock-set extender bar The second rear swing arm I soaked the lower pivoting ling in a big bucket of apple vinegar for 3 weeks with the central cotter pin removed to allow for more penetration in to the pivot axel, the idea is all the rust and corrosion gets eaten away which should loosen the fit of the axel. Sadly this did not help and I had to cut the axel to get the suspension pivot apart and I will have to press out the remaining axel . NITEMARE!! The Fuel Tank Resto The Fuel tank sas in terrible condition 10mm at least of rusty sludge on the bottom and rust everywhere you looked –I thought it was a throw away actually but I researched possible reco methods online and come with the following With tank fully removed I tried the scoria pebbles and cement mixer combination to internally sand-away the rust and it worked really well. Next step was to put in the 16 litres of apple cider vinegar which I will leave in for about 2weeks and flip it regularly, this should take out all the rust – concentrating on the seams by letting the tank sit on the seam sides for days. I almost considered not doing vinegar treatment as the tank looked so good after the pebble process but I am glad I did because a huge amount of rusty crap still came out of it after this process ;lots more rinsing Note you have to tape up all the holes in the tank I did this by using the good ole duc-tape and some zip ties to ensure the taped caps stayed in place, I used a typical spray can cap to seal the fuel filler neck with some duc-tape and zipties Pictures of the of blocking the holes in the tank below With Fuel sender hole I found a big washer and then I made two gaskets out of bicycle tube then screwed the lock ring down – perfect seal After washing out the tank several times and blowing out the pipes eventually the rusty crap stopped coming out Then I used Por 15 Metal clean to clean out the tank once more and neutralize the effects of the Vinegar Drying out the tank I did straight away by putting a heat gun in the tank filler hole in the lower setting and letting it run – I also put electric strip radiator heater on faced it on the tank – the tank was heated inside and outside it got pretty hot to touch and effectively dried out in about 30 min. Tank inside after the cement mixer treatment and vinegar and Metal Clean I put paint striper on the outside of the tank and removed the paint with a hand held wire brush, then used a wire wheel on 240volt drill to clean her up fully and get rid of any of the stubborn rust spots, tank is looking really new Then then I Used the 1st step of the KBS Gold Standard Fuel Tank Sealer Kit (Got this from Autobarn) 1st Step KBS kit is pour in 50-50 mix of Aquaklean tank cleaner solution this is mixed with 50% hot water Ieft this in 24hours and repeatedly turned the tank in this period and gave it a really good shake. Note you have to tape up all the holes in the tank I did this by using the good ole duc-tape and some zip ties to ensure the taped caps stayed in place, this solution should help get rid of the vinegar and neutralize the effects of the vinegar The next step is to proceed with step-2 of the KBS kit putting in the rust buster solution which I put in as per the recommendations an I made sure that the centre seam got extra time immersed in solution The 3rd step of the KBS kit is the silver tank lining solution which I again followed the instructions looks like really good stuff the tank is thickly lined in silver paint now and looks brand new. This stuff is super strong pretty impressive. Tank Finished and Painted on the Inside List of steps 1. Remove tank from car 2. Hire Large concrete mixer 3. Fill tank with 10mm scoria pebbles about 15-20% full 4. Strap tank to the front of the mixer ratcheting straps 5. Run for 1.5 hours on one side 6. Run for 1.5 hours on the other side 7. Add water to the tank and run mixer on highest speed until most of the water has come out 8. Get all the stones out and flush tank with water 9. Add the vinegar for 2 weeks and flip regularly 10. Take out vinegar and flush with water and detergent 11. Use POR-15 Metal Clean solution and dry the tank 100% 12. Sand blast or paint stripper on the outside of the tank 13. Add the 1st step of KBS Tank reliner kit witch is a cleaner, Give a good swish around 14. Dry out the tank fully used a Heat gun in the inside through the filler neck and also used a radiator style electric heater to heat up the quiet hot to get all the water evaporated 15. Put in the rust buster solution step 2 of the tank reliner kit 16. Dry out the tank fully used a Heat gun in the inside through the filler neck and also used a radiator electric heater to heat up the quiet hot to get all the water evaporated 17. Pun in the special tank relining solution swish evenly around the tank, tip out excess and let it dry 18. Remember to blow out the pipes before the reliner paint dry’s 19. Paint the outside with POR 15 BLACK GLOSS after making sure the surface is properly prepped Please note I also removed the fuel sensor system let that soak for 2 weeks in vinegar – cleaned that with POR Aquaklean and then used the rusbutster , then used the tank liner solution on all the outside surfaces except for float and the electronics. It was still some how working even know it was caked with rust Good lesson for all is to keep fuel stabilizer in your cars if you are only using cars occasionally. The modern fuels goes off quickly - off fuel and half empty tanks accelerate the rusting process – also keeping the fuel tank fully topped up will help slow rusting because nothing is left exposed to rust. $200-$300 on parts to fix the original tank may also be better than the original - a reco’ed tank from USA was about $600 without shipping so it was cheaper and no doubt done better than most reco’s but it was a lot of work. But thought of sending rusty crappy fuel down to a beautiful straight six engine is not something I wanted. The Reco Continues After finishing the petrol tank I then I proceeded to remove every part removed and I mean every part make sure you do this as behind bolts and brackets can be rust especially the door hinges so remove absolutely everything! I have 2300psi Karchner Jet Washer with a Sand blaster attachment (for wet blasting) I started to use this with the sand blaster attachment and it did work but it used a lot of sand and to do a small area and a lot of water it could be possible to do a whole car but the time and money for all the sand and the mess of wet sand in panels and building up in areas that you don’t want it to would not be worth it especially on the car body, on individual panels but it could be worth the pain and trouble. So I got a dustless bluster guy to come out and they use a much higher pressure water system the water keeps the dust down also keeps the panel cool and helps prevent panel warpage compare to standard sand blasting. It’s a new method and some people will say this method is not as good because of the use of water, but it is quickly becoming the preferred method of some professional spray painters The water used in the dustless blasting also gets treated with a rust inhibitor (called “stay tight”) to stop or greatly reduce rusting of the naked panels. I guess many of you are wanting to know how did work – It’s awesome to watch very effective at removing everything in its path except rubber, seam sealer, sound deadner and silicon, so urethane rubbers are not damaged, rubber protective bellows if in good condition also not damaged , the factory metal cable ties that spot welded to the panels to guide the wire harness ect, have the rubber coating also not damaged – pretty cool stuff. There is not a lot of excess water and not a lot of sand used either really. Its still pretty physical for the guy doing the blasting but you don’t even really need a dust mask – much better than sand blasting. This is what was blasted Suspension components – all parts Diff Tail shaft Grill Drum covers Removed panels This actually took about 8 hours and the body we left to another day which was another 14 hours. The body is extra labour intensive as the tar sound deadener and rust proofing on the under body actually needs to physically removed before the blasting as the granules of sand whether standard dry sand blasting or wet blasting will bounce off the tar rather than take if off – so out comes the vibrating scraper tool again – awesome for this hard task but it will still take you 12-15hours to remove the tar from the under body –kill me now. Also note the seam-sealer will also not blast off so if you want new seam sealer remove that also before blasting. Did I remove the seam sealer yes I did 90% of the time there was no rust under the seam sealer so not really worth it in my case but I guess it goes brittle at some point so it might be the best to get out now. I followed the dustless wet blasting with the POR-15 Marine Clean and then the POR -15 rust converter and which neutralizes rust and seals the panel with galvanized type of finish –both these process (Marine Clean and Metal Ready) use water so the whole process should work well the water based dustless blasting. The POR-15 systems will get very good penetration in to all the surfaces of the panels getting into the overlaps and creases . I also invested in some of the Rust Bullet paint this kills of neutralizes rust as well – comes with a 10year guarantee in fact, and is the industry’s best rust treatment solution by all the supporting evidence I could find. I am going to use this stuff for all the area where you cant see or get into , chassis rails, seams, inside panels , structural pressings around bonnet and inside the frame of the rear lift back frame , rear lift back hinge cavity – basically anywhere rust could or could resurface. This stuff you can see visually removing rust with each application and it also seeps deep into the rust, fully neutralizing - the POR-15 is similar but not a as aggressive what I mean by that great for areas that you get to remove most of the offending loose rust – but for areas where you can’t the Rust Bullet is more effective and is also backed with warranty!! On all the body work inside and out all the suspension parts, driveline I used the KBS rust sealer and the the engine bay rear boot space and the underbody the KBS body seal – I can only go application not on time being the true test - but for the money the KBS is great stuff works well and easy source and half the price . The sunroof delete has been a considerable source of contemplation I read everything on the forum and studied anything else I could find on the net. At one point I decided I was going heat form some 8mm thick arylic/Perspex to the shape of the roof and make insert to plug the hole. End result would have been moon roof .I was thinking of going this way because I am 6ft 2 and having the feel of more space with a sunroof and a fixed moon roof does not reduce the height of the roof line, this appealed to me, the hole is also larger than normal being a slide back is larger with nice curved corners so it will look good with tinted roof flush fitted acrylic insert. But I did a crazy amount of research on this and I found out that Perspex would expand maybe 5mm to 8mm possibly with the size I had to fill - which means you have to sit shaped pane of Perspex on a reassessed shelf with 5mm bed of silicon with 10mm silicon track around the whole Perspex’s roof to absorb the expansion from the heating on a hot day. So the idea of all this movement on a fragile roof skin made me abandon the idea. Now I am going to weld in the original sunroof blank and put this to rest. P-A-I-N-T originally I was going to keep the original Light blue its classic yes! but I wanted something a bit more muscle car and vibrant. I started to look at all the wild green options in the end after much contemplation and looking at and imagining the z in this colour for some time – 12months of seeing it that way - I settled on the MOPAR colour PFB SUBLIME GREEN METALLIC #5163154AA The sunroof delete Plan to weld in the original drop down and slide back sunroof blank. To do this by welding in inner lip around the inside of the sunroof hole, this would make it much easier to get the sunroof blank to fit at the correct level to existing roof line and also put metal around the edge to absorb the heat from welding and this would reinforce the hole in the roof line . So for these lip parts I was able to use the strengthening bracket which where folded into the edge of the existing sun roof blank this. These brackets are already shaped to the curve of the roof line and are quite strong. I got these welded in top place no problem front and back was fne and the sides to took a lot more fiddeling around because the side need more spacing to match the roof line In regards to Tyre/ Wheel Sizes - From what I can ascertain these are probably the biggest tyres that I can fit under standard rolled guards with MCA coil overs installed – I am giving you the tyre/wheel size just in case you think is worth changing the diff ratio? I plan to run in these in the future: · 16 x 7 (4mm offset) with 225/50 on the front – with Toyo R1R Tyres – Mags Made by Rota, RB model · 16 x 8 (4mm offset) with 245/45 on the rear – with Toyo R1R Tyres – Mags Made by Rota, RB model Will run the stock Alloy Mag Wheels (supplied with the car) five slotter kidney Bean until I have the budget to get the bigger wheels mentioned above. Stock wheel measurement are as follows · 14 x 6 (10mm offset) with 215/65 on the Front – with Bridgestone RE92 tyre - Mags 5 slot Kidney made in Aust. Samson Brand · 14 x 6 on the Rear (10mm offset with 225/65 on the Rear – with Bridgestone RE92 tyre - Mags 5 slot Kidney made in Aust. Samson Brand With the help of wheel calculator it says that there is minimal difference in the diameter is I go with this set up 67mm less circumference with the new wheel set up if the calculator is right. Front EXISTING front NEW Diameter 635.1mm 631.4mm Circumference 1995.2mm 1983.6mm Poke 66.2mm 84.9mm Inset 86.2mm 92.9mm Speedo error 0% 0.59% Reading at 30mph 30mph 30.18mph Reading at 60mph 60mph 60.35mph Ride height gain 0mm -1.85mm Arch gap loss 0mm -1.85mm Compared to your existing wheel, this new wheel will have an inner rim which is 6.7mm closer to the suspension strut. The outer rim will poke out 18.7mm more than before. EXISTING NEW Diameter 648.1mm 626.9mm Circumference 2036.1mm 1969.5mm Poke 66.2mm 97.6mm Inset 86.2mm 105.6mm Speedo error 0% 3.38% Reading at 30mph 30mph 31.01mph Reading at 60mph 60mph 62.03mph Ride height gain 0mm -10.6mm Arch gap loss 0mm -10.6mm Compared to your existing wheel, this new wheel will have an inner rim which is 19.4mm closer to the suspension strut. The outer rim will poke out 31.4mm more than before.
  23. Good To See All the hard work paying off! Well Done - thanks again for sharing the mods - AK
  24. No Worries - Thanks for letting me know. Cheers AK
  25. Hi Mike I am interested if they are road legal - I assume they would be just the green tint thing could be a problem? Their is also the complication is transport of such a fragile item to my location. (all screens would need individual packing from the factory. The other question for you if we are going to run of front screens for the club members as such does the company do rear windows with wires in them as well? I have 260 2+2 1976 model are the front screens and the rear windows the same across all models Sorry to hit you with more questions. Cheers AK
