zcar63
Everything posted by zcar63
  1. zcar63
    L 28 Bits needed
    Hi All I'm chasing a water pump pulley for L28 and ignition timing mark plate ,the one that bolts next to the crank pulley. The one i have protrudes to far forward of the engine to be of any use on the pulley i have.And the water pump pulley hub it to large. I would prefer to pickup locally to brisbane, but if anyone has something that might fit ,could you send a pick so i can verify please. Cheers Dave
  2. zcar63
    head gaskets
    Hi All Can someone point me in the right direction for head gaskets, engine has been bored and i need an oversize gasket. I would like to use an Australian supplier if possible. Cheers Dave
  3. Hi All I have a pair of rear control arms up for grabs. Please contact me by pm for details.I will donate $50 to the forum and another $100 to Wildlife rescue(WIRES) upon sale. $850 plus post. Cheers Dave
  4. i need a pair of front control arms 240z or 260z Cheers Dave
  5. Thanks for the update Gav cheers Dave
  6. Hi Gav i would like the doors complete, less the tin worm i have now Cheers Dave
  7. Ha Ha ,can i blame a busy day. 240z 1971.Maybe a pair of front seats with runners as well while your at it. Cheers Dave
  8. Hi Gav Put me down for a pair of front doors, do you need a deposit? Cheers Dave
  9. Chris Noble has a honda powered elise using an intgera engine i think,very quick at morgan park.
  10. Hi All Does anyone have a set of valve spring washers for a six cylinder head they want to part with ? the hardened ones that go between the spring and the head. Cheers David
  11. you can borrow mine , i'm on the northside Cheers Dave
  12. Thanks Jason
  13. Hi All I was wondering if anyone has a set of performance valve spring lying around they don't want .I bought a head with perfromance springs installed .............. The free length of the springs i need is 55mm not the standard 50mm. Cheers David
  14. Hi Agno The die net is just to chase the falcon thread, they often have flattened/damaged threads in spots.In the second photo you can see the falcon v datsun caster arm ,more adjustment available on the falcon arm.
  15. Hi All This is not my idea,i pinched it , there maybe other ways to make it work .This is what I did to make it fit. If you find i have omitted anything or missed a step ..................... First ,BE SAFE, jack your car up and use some sound axle stands before working under your car.Take some measurements of the caster arm length to front lower control arm. Use this measurement to get close to what you had after you installing the new arms .Then get it properly aligned as soon as possible. The thread on the Falcon caster arm is 18mm x 1.5 Tools needed: - Pair of Ford XD,XE and XF Falcon caster arms with nuts and large cupped washers - angle grinder with cut off wheel and flap disc for finishing - drill press or pistol drill - 10.5mm or 13/32" drill bit - Marking pen and scriber - round file( Lots of elbow grease if you use this) - spanners or shifters to fit adjusting nuts - bush kit from Mazda RX7 series 1,2 and 3, Nolathane Part no 48021 Try EZIAUTO parts on line Tool that will make life easier if you have them : -18mm x 1.5 die or die nut - 26.5mm reduced shank drill bit -18mm or 23/32" drill bit (to drill ZCar cupped washers) -Die grinder - vice -clamp -powder coating(optional) Zcar in foreground Falcon at the back Thread on Falcon arm extends down further from the end an are larger diameter Knock out the facon studs place z car arm over falcon arm and mark where the new holes go. lop off the end Spot drill ,and then drill through on the drill press Notch out small area to miss the swaybar drop link Drill or grind or file the mounting hole on chassis brackets to accommodate the larger diameter bush kit The hole required is approx 26.5mm with this new bush kit You can drill out the Zcar cupped washers that go either side of the mounting bushes or maybe use the falcon ones
  16. the Ozdat one
  17. just picked up R180 LSD with 4.1:1 ratio
  18. Hi All chasing an L28 block , bare block with main caps is ok as i have a couple of cranks i can use.Standard bore is preferred ,or able to bore to 87mm is what i need to suit the pistons i have. Pay cash or part exchange for some of the parts i make . tell me what you have and we can work it out. I make front control arms rear control arms steering arms with ford ball joints Cheers David
  19. zcar63
    L26 Block
    Thanks Lurch
  20. zcar63
    L26 Block
    Hi Yall Any gestimates on how much you can safely bore an L26 block ? I'm a little retentive in the back passage at the moment, and don't want to fork out MORE money to engine shop, for sonic testing or anything else ATM ,I'll get over the passage issues soon but for now any opinions on the L26 are welcome.
  21. Dave Boddy was Peter Brocks Navigator in the 1995 Round Australia Rally i think.
  22. Hi All I have new set of cast pistons with rings for an L28 with 1mm over bore.They are 87mm with a dished top.See photos for more information. Items are located in Brisbane, pick up is fine ,or i can post at buyers expence.$150.00 negotiable.
  23. Just like to say ,great effort from Mr &Mrs Siddins to win their class in Targa Tasmania 2016.Final got your hands on the trophy,you bloody ripper great car, great drive. Cheers David
