zcar63
Everything posted by zcar63
  1. Cheers Mate ,are you running these inserts?
  2. Hi All i have seen some of these insets sold on the forum recently,can anyone supply insert sizes please.Open length,closed length ,shaft diameter and insert diameter. Thanks David
  3. zcar63
    WTD:Front arms
    Hi All Thinking of making front lower control arms adjustable,i don't want to cut mine up .If i get a couple of pairs i might make some for the market.please tell me what you want for them and i can cover postage. Cheers David
  4. zcar63
    gearbox id
    Hi all been researching,it might be from a nissan gazelle,it might not have the best ratios but at least it has a proper synchro on fifth. Cheers
  5. zcar63
    gearbox id
    Hi all pulled my gearbox out to give a once over.I checked the ratios to see what i've got.Well all is good ,but fifth gear is 0.832 and it has normal synchro on fifth as well.Most of my checking has 280zx box with 0.863 fifth and fibre ring instead of brass synchro .Any suggestions what it is off? Cheers
  6. Might be oscillator box for rally clock
  7. (hey that's me in the blue shirt)
  8. If anyone has a dividing head or/and rotary table we might have a deal to be done in exchange for the control arms. Cheers David
  9. Hi All I Might have enough material to make another pair of arms, is their any interest ? Cheers David
  10. Hi All Made a pair of custom tie rods as per Whittie's instructions( A BIG thanks to you Whittie),also knocked up a pair of front adjustable control arms a few weeks ago .The control arms are mounted through the original holes in the cross member.I have some bumpsteer spacers, but the angle of the control arm and steering arm look good to me,so the spacers can stay in the packet.The car is on full droop ATM i might remove the coil spring to see the full travel just to be sure.I can't find any inner steering arms of the left hand variety and hints would be good. Cheers David
  11. Hi jake i want to make some adjustable arms using the cranked end part then my own bits as well.By the way what is the best model subi to get a diff out of,i'm looking for 4.44:1 ratio or there abouts with a clutch pack centre Cheers David
  12. Thanks all for the replies i have now got a pair,the forum comes through again Cheers David
  13. Hi Guys/Gals i am after a pair of castor arms for my 240z i think 260z are the same,anyway will to pay a handsome price cheap is good and i will cover postage if needed. Cheers David
  14. jason I am on afternoon shift this week i start 2pm, what time is ok? Cheers David
  15. Jason i live not far from you, could i throw them in the car and bring them over for you to have a look at.or will posting photos be enough? Cheers David
  16. Hi Jason What do i look for inside the box to tell it apart from others.What is the main differences between a 280zx and a 240k for instance,ie gear size ,synchro type I know first gear on the boxes i have on the floor are both is 3.321:1 cheers David
  17. Hi Jason and all Thanks for the replies My current box in the car is a 280zx the 2 other boxes i have on the garage floor both have a first gear ratio of 3.321:I presume that ratio is only found in 280zx models.So Question 1 :Are these 280zx boxes i have in the floor Question 2: Is this first gear ratio found in other gearboxes ie 260z/260z 2+2 Question 3 :Could they be from another model ie 240K,200b,skyline,etc I want to rebuild the box myself so i need to know what kit to buy from SW Motorsport Buy the way Jason do you have any R180 lsd centres?
  18. Hi All i had a look on the forum but can't find any info about how to identify z gearboxes.I picked up 2 boxes a couple of years ago from a wrecker i have checked the first gear ratio and both are 3.3,one had 260z in paint pen on it but i think that is incorrect.I need to replace the one i currently have in my z,and i want to rebuild on of these boxes ,i need to know what kit to order .Can anyone on Brisbane Northside have a look and suggest which kit i need. Cheers David
  19. Hi Guys If gav 240 doesn't take it will be interested. Cheers David
  20. Hi Guys/Gals I 've just had them electroplated, the plating only goes an inch(25mm) or so up inside the tube
  21. Hi All Is anyone will to sell me an R180 LSD complete/or centre only in exchange for some adjustable rear control arms and cash adjustment.See the control arms in the Suspension section.or the picture below Cheers David
  22. Hi Jake I try to lighten the parts where i can ,i think i must be channeling Colin Chapman (see Lotus car company) Cheers David
  23. Hi All Electroplating stuff as far as i know.i went down the road to see a couple of blokes i know the other day to have a chat about car stuff and he told me the electroplater across the road had reopened.Google "Eastcoast electroplating" and all will be revealed Cheers David
  24. And More
  25. Hi All A few photos for your pleasure Cheers David
