bryan3976
Everything posted by bryan3976
  1. Bump who’s using the bc coil overs and what are your thoughts on them
  2. Few years on I find myself still enjoying the car and really haven’t had any issues but I do feel it’s time for upgrades again so I find myself looking and reading up on things again. to do list new exhaust to fix leaks . suspension Probably to bc coilovers as the current setup is nothing special. new front air dam. heads getting a little noisy so ill adjust the valve clearness or build another one.
  3. hey mate i have freind interested he tryed to call you but couldn't get a hold his number is 0401 338 094
  4. yep and my first attempt
  5. was time to get a tune on my frst engine build l28 n42 head with 68 deg works copy .40 over bore with dished pistons high flow oil pump stock manifold and cheap extractors i wasnt to happy with the power out put but was my firsst attempt at building a motor plan to try some new things in the new year with a modified intake and suggestions or tips would awsome .car drives amazingly now.
  6. shocks works will also do it
  7. i also bought a zed when i was younger as a project your skills and knowledge will grow as you progress enjoy it
  8. $700 with re002s rears need to be balanced will consider swaps. will post with out tires
  9. You can strip alot of the manifold for a cleaner look if that's all your after .
  10. looks like your on the right track just keep at it
  11. Chaseing s higher ratio but thank you .
  12. Still in need will take r180 if it comes with half shafts in 4.6
  13. woops i ment 225 and yes hoping to see it run down the 1/4 eventually . first pic is ssr wantanbe in 15x7 +20 ish next set 15x8+20 enki rpf1s i will be going to +0 soon
  14. Some new shoes in 15x8 +20 front has nankan semi slicks and rears are skiders atm till i get some 255 60 15s mikys Im going to attempt fuel injection conversion this weekend as i have all the kit siting there. will be all stock kit then upgrading to a tunebale ecu with ls1 coils and bigger tb sr or xf with cable throttle. Thinking of upgrading my diff theirs a 4.64 ratio diff for sale atm would that be street able ?? Heres a diagram i found hopefully it helps but if any one has better info pls link me
  15. would the head work on a l28 block ? or would it be to high comp?
  16. 3.9s or 4.1.1 open locked or lsd
  17. looking for 40s but will consider everything prefer with linkages manifold for a l28
  18. still a few things i want to fix *rb20 gear box *lsd *bigger brakes
  19. bit of bump but who would be best person to disk mods in vic ?
  20. as above would prefer a complete kit so its just a bolt on bleed and go.
  21. just extend the lca alot of drifters do it . bolt it all up look at how much you need to extend it by and weld away.
  22. It did but has been sold
  23. was just a standard ecu was gonna up the fuel pressure. then go aftermarket.turbo sold exaust manifold $180
  24. open to offers
