waxhead
Everything posted by waxhead
  1. I had a dream about a even better intake manifold and im wondering if anyone out there has an intake manifold for an injection l28 Dont actually care about the condition i only want the mounting fact for the injectors must be cheap 0410665701
  2. Do you have the template still
  3. Is this still for sale
  4. Ha ha ok you got me Maybe i need the bigger diff huh
  5. Maybe run a twin entry ballbearing turbo Boos lag is really a thing of the past nowadays with modern correctly sized turbos
  6. can you program your ignition if so then give it more timing off boost to account for the low compression that will help fatten up the low end power
  7. Ok thanks for that Im not about doing burn outs every where so it should be ok I was thinking about getting an lsd for it , i dont really want to weld it as its going to chop out the tyres something terrible
  8. But what does the sphincter grab when your coming into hot. your better of removing the brake pedal Less weight and it will definitely increase your corner speed
  9. yeah ok i will do tomorrow I will be keen to see what else he has for the z car as well I need to start making some decisons about my suspension setup
  10. Im not sure about your l28 but under my intake manifold i have an exhaust system I think they may get in the way of the supercharger
  11. you could cut the floor out under the seats you dont need them and you can chuck your rubbish straight on the road no one will know it was you plus getting rid of rubbish will keep car lighter
  12. How much were those bushed lurch Im just starting work on my suspension now, still debating in my head if to change to an r200 diff now
  13. Cleaned out the back a bit today I have some work to do to fix this guys back to metal job that never was Its all good i will get there , hopefully new suspension turns up next week and so its back on the wheel then wait for the rubber to get here Man trying to get that through bolt out in the rear suspension is proving to be a chore, I think i will bring the gas axe home from work and heat it up some more
  14. ok thanks Im going to try and push more than that through it Looks like i will have to go foo another one later down the track Guess its time to look around for an r200 cheap
  15. So your saying that they arent that strong I heard they were not to bad??
  16. Well working under the guard hopefully the new front suspension will be here next week so i can bolt that in with the lowered srings Just found out that some one bolted a r180 into my car and took the r200 for themselves not very nice of them Oh well a 180 is lighter and will take the load of a turbo l28 so its not so bad
  17. True you may need it at some stage
  18. The gearbox is very heavy on these cars
  19. Yeah a pair of socks was killed in the making of these pipes I didnt want them to look all the same i actually wanted them every where makes it look more complex
  20. Yeah pipes every where Hard on a non cross flow engine as you cant go up only down and out
  21. Well the manifold is almost ready to be machined now Actually there is 5 mins of cleaning up top be done but i will wait until its machined first then clean it up and off to the coaters let me know what you think im stoked with it
  22. Im happy to butcher my trim so its all good But as mike said if your trying to keep it orginal then dont
  23. Im planning on mounting mine in the doors at the front And also in the back as well
