waxhead
Everything posted by waxhead
  1. waxhead
    p90 head
    Arent they the highest flowing head you can buy from nissan for this engine
  2. waxhead
    p90 head
    Fair enough. I thought they would be more. Guess i will just hold onto the one i have then .
  3. waxhead
    p90 head
    Ok thanks
  4. I can buy it for you Just need a deposit. I can get stuff in from japan. The joys of a japanese wife
  5. waxhead
    p90 head
    Im not sure if this is the right section to ask this in But can you tell me what do you think a p90 head is worth
  6. Ok so not on ebay but it is an auction I was about to buy it out of japan but then logic got in the way http://page8.auctions.yahoo.co.jp/jp/auction/h128280728
  7. Yeah i thought the price was right.I was really after the gearboxes But will take the engine as well. I think i will port the cylinder and put back on ebay Im thinking about getting into to more 4 stroke porting .After 15 years building race two stroke engines its time to start back onto 4 strokes where i came from.
  8. The spade terminal on there is an earth You shouldnt need to hook it to anything The dizzy is 180 degrees out It should run fine that way its just been put in with the dizzy turned the wrong way
  9. Yeah i will be suprised if it is anything other than the std cam. But i guess i will find out when i pull the cover on it
  10. Yeah i got that engine, I reckon it was a good buy. Cant have to many spare 5 speeds when you turbo your l28 It comes with two 5 speeds as well.
  11. How much power can this gearbox handle before it splits down the middle and you end up walking home.
  12. this is the manifold with the side panels on Well sitting in there anyway Its almost ready to be welded shut now
  13. Well got the manifold all tacked up today and have to blend the old body in to the new plenum Then its a case of welding it all up and making a top and bottom plate and then manifold is finished On the bottom plate i will weld a thicker plate so i can put in the map sensor and vacum fittings oh i wore my socks to keep every one happy as well
  14. I will come and meet you guys one day But thats the day i work on my friends sports sedan Every wednesday
  15. Its seems a fair way off the front on the throttle body But i see your design and its further. Im not getting to stressed about it , The flow is going to be far better than the orginal and since its going tbe force feed i think it will flow enough to reach my goal of 300 to 350 whp Thahks for the comments
  16. I teach welding as part of my job Lucky me i have access to all sorts of welders I prefer mig myself it so easy and striking an arc is never an issue like a stick welder
  17. Nah not for me Its more than likely what you need in your car for your track work
  18. Man easy I am a kiwi. A thong is something my wife wears The Jandle is is something you wear on your feet or use to prop up unwelded intake manifolds.
  19. I have been looking at the ecu as well It looks like quite a good thing
  20. Ok having a look around i saw some other manifolds other people had made and i like the way they flowed them into the front cylinder. I could see a shortcoming on my first design So i changed it a bit today, I think it will look alot better and should flow alot more as well. Of course it needs to be welded up and its just held together with tape at the moment. Hopefully i will get it tacked together on wednesday and then will make the plates to over all other holes. Should be excellent when finshed
  21. waxhead
    cam for L28ET
    oh ok i didnt realise you were trying to go that hard with it Then your right an rb would be a better thing for you
  22. Thanks They are my favourite socks Im happy with the way the manifold is coming along. Hopefully when its all welded up it will look as good as it does in my head
  23. Well did some more work over the weekend Hopefully i will have the manifold welded up this week [ Stripped down the spare l28 that came with the car today all cleaned up enough to go in the back of the car now Will go off to get hot tanked this week
  24. waxhead
    cam for L28ET
    Not sure how its false economy. get on trade me buy an exhaust manifold for 200 kiwi. Intake manifolds are every where if you want to go crazy then buy forged pistons but hey you will need those for the rb anyway , ecu well you need one for what ever engine you build I actually think the l28 turbo will be cheaper than an rb,you dont have to buy the sump ethier. Plus they get up to 400 at the rear wheels on the stock exhaust manifold How much are you after
