Everything posted by .
  1. Who has the largest zed collection? (I have three not including all the parts)
  2. .
    KHGC110 project
    Yeah I payed a fortune for my Toyota Starlet because the owner told me it was a 2000GT. I thought the nose was a bit short.
  3. Nope, haven't bought one of those but it has inspired me to make my own.
  4. .
    Speedo drive cog.
    Can someone please check my logic. The background: I have just changed my diff from a 3.9 to a 4.6 My current speedo is in Kmph. There is no speedo cog to suit the 4.6 ratio When I am actually travelling 100Kmph my speedo tells me 140 So heres my plan (I'm broke so I can't afford a new speedo) I figure by changing back to a Mph speedo but reading it as if it were Kmph would then read 87 when I was actually doing 100. So then I need to adjust it a bit more to get it almost right. Assuming I have the 19 tooth cog (I need to check this) I multiply 87 by 19 then divide by 17 to end up with 97.2 In other words if I change my speedo to Mph and get the black cog (17 tooth) my speedo should be usable again. Thoughts anyone?
  5. nice!! is that shag pile?
  6. Where are you? I have one in Brisbane if you can't find a closer one. Thanks Greg
  7. thats the clubman circuit. 69 seconds isn't all that fast but its only my second time there so I still have some room for improvement. As it turns out I didn't go any faster in the last two laps which surprised me a lot. They felt so much quicker. Not sure where I am going wrong.
  8. .
    Weird Rubber Bits
    I have started on a mould for them but I have been extremely busy and haven't got further just yet. The next week or so should be better for me. I'll keep you all informed of the progress.
  9. Yesterday at QR I know I did at least a 69 second lap. I have only seen the results of the first three runs so its possible (I believe its likely) that I might have a better time again. I was only just starting to get brave on the last couple of laps. 69 seconds is 5 seconds faster than my previous best.
  10. The Interpretive Guide to the Haynes Maintenance Manual Here is a secret translation of the contents of this manual which you may find helpful Haynes: Rotate anticlockwise Translation: Clamp with mole-grips then beat repeatedly with hammer anticlockwise. Haynes: This is a snug fit. Translation: Clamp with mole-grips then beat repeatedly with hammer. Haynes: This is a tight fit. Translation: Clamp with mole-grips then beat repeatedly with a hammer. Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox. Haynes: Pry... Translation: Hammer a screwdriver into... Haynes: Undo... Translation: Go buy a tin of WD40 (giant economy size). Haynes: Retain tiny spring... Translation: PINGGGG - "Where the hell did that go?" Haynes: Press and rotate to remove bulb... Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a plaster or two). Haynes: Lightly... Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with mole-grips then beat repeatedly with hammer. Haynes: Weekly checks... Translation: If it isn't broken don't fix it. Haynes: Routine maintenance... Translation: If it isn't broken, it's about to be. We warned. Haynes: One spanner rating. Translation: An infant could do this... so how did you manage to f*** it up? Haynes: Two spanner rating. Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you). Haynes: Three spanner rating. Translation: Make sure you won't need your car for a couple of days. Haynes: Four spanner rating. Translation: You're not seriously considering this are you? Haynes: Five spanner rating. Translation: OK - but don't ever carry your loved ones in it again. Haynes: If not, you can fabricate your own special tool like this... Translation: Hahahahahahahahahahahahahahahahahahahahahahaha. Haynes: Compress... Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer... Haynes: Inspect... Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yes, just as I thought; it's going to need a new one" Haynes: Carefully... Translation: You are about to suffer deep abrasions. Haynes: Retaining nut... Translation: Yes, that's it, that big spherical blob of rust. Haynes: Get an assistant... Translation: Prepare to humiliate yourself in front of someone you know. Haynes: Turning the engine will be easier with the spark plugs removed. Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs. Haynes: Refitting is the reverse sequence to removal. Translation: Yeah, right. But you swear in different places. Haynes: Prise away plastic locating pegs... Translation: Snap off... Haynes: Using a suitable drift... Translation: Clamp with mole-grips then beat repeatedly with hammer. Haynes: Everyday toolkit Translation: RAC Card & Mobile Phone Haynes: Apply moderate heat... Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with mole-grips then beat repeatedly with hammer. Haynes: Index Translation: List of all the things in the book, bar what you need to do.
  11. There is a reason they called them sevens....Gives you an excuse to have one for each day of the week.
  12. I have sent you another one
  13. There is only one thing worse than being overtaken and that is being overtaken by your own wheel
  14. no officer. I didn't lower my car....its just that the ground is higher here.
  15. hmmmm. Brain wave. Add a timing light in the engine bay. Add a video camera pointing at the pully. Then add a TV in the cabin so you can see what the timing is doing while driving. Brilliant!!! I don't know how I survived without it.
  16. The Z Car Club QLD is holding birthday celebrations for the 40th anniversary of the zed. They will be held at Lakeside including sprints. It is open to all zed owners (not just club members). I am not organising it just passing on the information. Here is a summary: 26th & 27th September 2009 – Special Event 40 Years of Datsun – Nissan Z Series and 25 Years of the Z Car Club of Queensland This year we celebrate the 25th birthday of our club and the 40th anniversary of the release of the 240Z. To mark this significant occasion, the Z Car Club is holding a fantastic event which will combine social and motoring and allow you to enjoy your Zed to the full, in safe and controlled conditions, whilst challenging your navigation and driving skills. The event will be held over a weekend. On Saturday there will be a navigation event of two hours duration, starting at Mt Cootha and finishing at Winenhoe Dam, with a BBQ lunch. Then on the Sunday will be a driving skills event at Lakeside Park on the following day. Points will be awarded in each event and there will be an advance and novice class. There will be prizes for class places in first, second and third. If you wished you had participated in the Nationals, then here is your chance to have a go! More details to follow soon. If you would like to find out a bit more, talk to Aubrey Hughes on (07) 3200 4624 or see details on www.zcarclub.org.au or email to vickiih64@optusnet.com.au
  17. No joke!!! Where do you sit? You obviously work here somewhere
  18. I believe they complete the line of the car. Look from the side and imagine a line running down the bonnet. Without them the line drops off the front edge of the bonnet. With them you get a more rounded appearance to the nose of the car. Its all up to personal preference. You'll get arguments both directions....but you already knew that
  19. I don't know of a H4 with a curve. But I have purchased headlight protectors that hit on any round headlight. They are clear plastic and have more of a curve to them. Ask at your local accessories shop. You might have to try a few before you find them. They last about 4-5 years before they start to get opaque.
  20. you need to do a H4 conversion unless you already have H4s in your car.
  21. .
    OER induction
    wow. Now all I need is to fund the purchase......anyone want to buy a house I slept in my 240z at Wheels in Wide bay no reason I can't move in permanently.
  22. .
    KHGC110 project
    I heard of someone locally building a GTR replica then selling overseas telling the buyers it was real.
  23. Yes the shafts will fit from a R180 into an R200 so long as the number of splines is the same. I hear conflicting stories about the length of the shafts though. I had heard that one shaft is shorter for an R200 to allow for the wider diff. But all the shafts I have seen are the same?
  24. I only found out the reverse rule after the run. Had I known I would have just driven forward. There was still a chance I would have missed that flag any way. In a championship event it would have been a WD but they are more forgiving at the come try days. No times yet. Maybe in a couple of days.
  25. here is me make sure to watch the run that starts at 3:50 even though my wife says "not quite" I actually broke the beam with the flick which means I was totally successful. The last little adjustment to get in the bay does not count in the time because the beam was already broken.
