Selling my set of triple 48 Italian webers. They come on a matching Tomei Japanese performance manifold with linkages. Very good condition. I will not be using on any future project at this stage. $3000-
That was my datsun 2000 and I expected Hung to grip up and head inside a bit, I stayed on the grass and came back on luckily. Scary just the same as you know there are cars behind as well.
Would like to find some steel wheels for my Z so I can fit the original hub caps. Is there anything readily available to suit in 14 x 5.5 or 14 x 6. I have a set of roadster 14 x 4.5 but I have been quoted $200- per wheel to fit new outer rims. I tried skyline rims but the offset is to large, Thanks.
Yes Tom. Would like to think there was a steering failure, last corner, last lap, last event. Tyres came off rim, bent back and pushed rail in bending caster arm. Will pull out ok and car will get that respray. I will try and attach photo.
Lynx manifold and 4 x Dellorto DHLA 45 Carbies, no linkages to set up triple carby set up $700-. Matching extractors also available if required $150-
John 0408396773
Look up Z Car Depot in US or US Ebay for 240z fly wheel. approx $330- plus $90- us dollars posted for a light weight machined one in the correct steel. Cheaper than local purchase by a long way.
Look for another car. If the internal condensation has created that much rust, there will be more as the bodies were not rust proofed when built. They are around in much better condition and repairing this, although possible would not be cost effective. Consider parting this one out as a way of maximizing the purchase of a better one. Cheers
