d3c0y
Everything posted by d3c0y
  1. Here's a 2 seater with the same treatment:
  2. Another victim of not reading HS30-H's fender mirror diagram notes properly too... i hope it wont cost too much to reweld my guards and put them in the right place - i made the same mistake...
  3. Hey Guys, A few people have asked me to do this so i've pulled my finger out and scanned the diff feature out of G-Works magazine issue 8 i picked up in Japan at the start of the year. Yes it's in Japanese but there is still tons of good info you can take from it. I also have anohter issue with rebuilding mikunis, sumitomo calipers etc... heaps of good stuff! Don't forget it goes right to left when you are reading it. http://i101.photobucket.com/albums/m46/d3c0yz3d/240z/SKMBT_C28011110809210.jpg[/img]
  4. d3c0y
    300ZX twin turbo
    I'm keen on the block and crank from your motor with the blown head gasket as long as it's stock bore and has hand the shit detonated out of it.
  5. I've got .555 Lift cam 310/300 duration and .300" lash caps to be ground down, 38mm exhaust valves and nismo sump gaskets if you are interested
  6. Don't know at this stage - BiscuitBalls(Gavin) is coming over to my place on Sunday and i can give them to him so at least you will only have to pick them up from Carina then. I'll just PM you my bank details. All good?
  7. $65 Eleminate the weak point in your L-series engine and replace your tired weak factory rod bolts with these brand new ARP items. Never opend and comes with assembly lube. Located on the Gold Coast.
  8. I bought one of Phil's front bumpers and its pretty good for the money. He does a lot of different panels for all sorts of cars - even complete mustang bodies.
  9. What about tyre distortion when you go around a corner? I would take it for a hard drive then bring it back and take the wheels off and throughly inspect for signs of rubbing.
  10. I had to google this myself you are lazy! http://forums.hybridz.org/index.php/topic/92525-aardvark-my-vq35de-engined-track-car-with-s13-suspension-and-custom-widebody/page__st__20
  11. That's not a problem - it's the way it should be There is a build thread over on hybridz for this thing - it's insane!
  12. Come people cut the end off the CVs and just weld the Z flange (hub side) to the end of it.
  13. I agree the R200 Shorty isnt a bad idea - i was just asking if you were thinking about going R230. Apparently you can put the short nose carrier in the long nose case though, saving yourself another $450 + pp. If you could find out the thread pitch and ID of the TTT lower assembly you might find that jap coilovers screw into them. But yeah more rooting around. Whats wrong with a Subi diff - R180 - bolts in, lighter and converts to CVs which your motor will need anyway? How much hp is your motor going to make when it's done?
  14. I picked up a pair of HKS Hypermax performers 7kg & 8kg for a GDB WRX off ebay in mint condition for $450. Just remember that you dont have to get S13, you just need the correct OD on the shock body and a top mount that can be swapped for the zed type. Check out the thickness of the shafts on these bad boys: Just gotta scout around, i couldnt buy good nick second hand coilovers in Japan for that much and trust me i looked! I went to Hasegawa in Tokyo and everything for S13 R32 was flogged and shiver or it was brand new and they wanted $1500+ Here is a Hybridz how to on an S130: http://forums.hybridz.org/index.php/topic/94002-how-to-install-s13-coilovers-on-280zx-and-poly-bushings/
  15. Do you want to install a shorty R200 or an R230? 230 is complete overkill for an S30 in my mind and sooooo heavy.
  16. Sold.
  17. That looks hard compared to a Subi R180...
  18. There is no point running flairs and not cutting. It will look like a 4wd and you will stuff all suspension travel. Either cut or go 8" - 8.5" max. And it depends on the tyre shop - somewhere like K-Mart Tyre and auto wont do stretches.
  19. My Zed keeps good company:
  20. Apparently so, Pete mentioned that just before too.
  21. :-*Found the Americam Specs i had saved away: CAM LIFT IS 555 WITH 300 INTAKE DURATION 316 EXHAUST DURATION CAM IS GROUND ON 111 DEGREE LOBE CENTER BRAND NEW CUSTOM GROUND CAM USES LASH CAP # 263 Valve Spring Specs: http://www.nismo.co.jp/en/products/competition/engine/pdf/vs_6cylinder.pdf
  22. Thanks for the comments guys. I'm talking RPM limit not max HP, and will probably need 50mm induction to reach it and still have some point to revving it that high. I dont really care if it can't it would just be cool , i love high revving N/A engines. It's going to have a forged lightened bottom end. The info that Don Potter had with the head said that the head could be welded - there are two spots. Holes only showed up when the head had some dye treatment put on it. I was doing some reading on hybridz last night and apparently Potter was known for building Electromotive-beating L28ETs so i figure his cam and head should be a good place to start. @Gav: Yeah i've had Zs since 2000 and we've lurked around the same forums for a lot of that time Also true about how cheap zeds really are! Lol @Simon: No i didnt zero it - it was just for comparrison of lobe height. @Handsandwhich: I was tossing up whether to lead you on with this one, but no that is my girlfriend. I thought you guys would prefer a female parts model.
