d3c0y
Everything posted by d3c0y
  1. Couldnt you just get a bit machined off the hub face of the wheel? and then you could make a 0 offset a +10 or whatever you wanted? I bet that's all they do for the "custom" wheels. I'm just running low king springs at the moment but will be going to 400# HKS coilovers shortly. My point is you can probably fit the ET 0 so no custom ordering or machining
  2. Yeah man ages ago.
  3. 20 Year old, 150,000km+ 2.0L Turbo performance engine isn't going to be in the healthiest condition really is it?
  4. I reckon with +4s i could fit a 235 under there it's only 5mm more to the outside. I can measure tonight if you want? My car definitely sees high suspension loading the tyre has been touching the inside of the fender at the top!
  5. I dont get why you are so set on +10s? 16x8 +4 have plenty of space in the front and yes you have to spend $100 rolling the rear guards but its not that bigger deal. The extra 4mm you get with a 0 offset isnt going to ruin anything and will give people with stock suspension a touch more clearance which would come in handy on a 260Z with the high purches on the rear.
  6. They dont make a +5 in the RB only +4. 16x8 +4 will fit front and rear with 225/50s but you will need to roll your back guards. I wouldnt go with +10s on a Z when there are better options. http://forums.hybridz.org/index.php/topic/103675-rota-rb-r-17x85-4-offset-what-size-tires/ here is a guy running the 17x8.5 +4s and they fit fine. Amazing what you can find when you search the internet? I'm going to say you arent going to be fitting 9" rears on with -5 offset. If you read the post about backspace i wrote in this thread you will be able to work out if it will fit but im 90% sure they are going to stick out. On top of that chances of running a 9" rear without coilovers is pretty much 0. In saying that im only experienced with 2 seaters so maybe the 2+2 will - maybe it's time to research it a bit yourself...
  7. Hey Guys, I have two sets of brand new C Pillar badges ready to ship still in the Nissan boxes. $120 a pair including shipping. You will pay $125 from the Nissan dealer plus you will have to wait for the LHS to come from Japan so grab a bargain!
  8. How much is it to post one of these to QLD 4220?
  9. I'm still here :-* :-* :-* :-*
  10. How are S12Ws to big for the street?
  11. I think that the base settings on the site i posted would be a good starting point. The ducati 900SS is 450cc per cylinder and if you have a 2.8L you have 467cc per cylinder. Checkout the specs of the Ducati 900 Super Sport below. It's making 40hp per cylinder and just under 100hp per litre. So if you have an L Series doing those kind of figures you will be pushing 240hp at the crank which is about right for a trick carb setup 2.8L with some head work, it's even a 2 valve OHC!: Engine 904 cc SOHC 2-valve Desmo L-Twin Bore / Stroke 92 × 68 mm (3.6 × 2.7 in) Compression ratio 9.2:1 Power 80 hp @ 7,500 rpm Torque 57 ft·lbf (77 N·m) @ 6,500 rpm Base Jetting for 41 FCRs on Ducati 900SS: Fuel screw mixture screw 3/4 turn Slow Air Screw 1-1/2 turns Float height 9mm Main Jet 155 Main Air Jet 200 Slow Jet 60 Needle EMT Needle Clip 3rd from top That article says that it's a little rich from the factory so i think this would have you gunning close to a decent mixture on the L.
  12. Lol faster than his fingers can press the letters by the looks!
  13. With a 2.8L / 6 you are only getting 466cc per cylinder. 1000cc V-Twins have more capacity per cylinder and probably running more compression so I don't know if the vacuum thing would be an issue? Just googled - Ducati 900ss, KTM 950 Adventure Anyway this page also lists a basic tuning guide for FCRs - you did search the Internets already though right? http://www.ducatitech.com/2v/fcr_faq.html
  14. You would be lucky to fit those offsets without coilovers. I think dat2kman has a point...
  15. In future there will be no books! Everyone will just be reading PDF files on tablets!
  16. Maybe we just cant work out why Nissan went for a "high tech" trailing arm rear suspension in a newer model With the current price of Z32s why wouldnt you just buy one of them if you are set on a 300ZX track car? Wayyy in front of a Z31
  17. Hey you cant talk like that on this forum! You will offend all the Z31 members!! Or are they not as sensitive as 280ZX owners?? LOL
  18. I got these same seals from Rare Spares like 10 years ago, they are generic holden seal too. I had the same style on my hatch and found it was a bit too tight though. http://www.ebay.com.au/itm/VN-VS-Holden-Commodore-Front-Rear-Door-Seal-GREY-/300636745258?pt=AU_Car_Parts_Accessories&hash=item45ff58ae2a VN - VS commodore seal is the same...
  19. It's rotary... isn't that normal??
  20. 300ZXs need their own forum because of the massive amount of problems they have. All their breakdown threads would clutter our forum haha.
  21. Shortly I will be able to contribute a sheet for a PMC L34
  22. Biscuit Balls has one of the Nostalgiccar.com seats and it's frigging tiney! Harness holes are like halfway down my back.
