Scoota G
Everything posted by Scoota G
  1. I am going to fit one into the V8 conversion i am doing because the transmission mounting point gets in the road of the shifting rod. But C4 fitting is store bought. I'm sure they had shifters to suit Jatco on ebay but.
  2. I don't know what to say about that, it's just an exercise in logic. Like move the position of the cable up or down the shift lever to match or make up a new lever (the one that connects to the gearbox)
  3. Yea you can see that the No 3 cylinder is the same one you have the hose from the rocker cover running to. Most prefer a catch can! Check how much blow by you have by taking off the oil filler cap while idling.
  4. The Mob has spoken, lose the nudge bar. Well done on the purchase Sam, bargain of the year!
  5. I bought my drivers side regulator from the States so it wasn't as used. http://www.ebay.com.au/itm/75-76-Datsun-280Z-set-window-regulators-74-/160879297539?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2575274403
  6. Sort of looks a bit like my 260 when i first bought it in 1997. The 240 is from Geelong area yes?
  7. Ever thought of fitting a hi-stall?
  8. Quoted as being unbreakable. RB30X does the shift kits for them and they work very well. 1st to 2nd is a big size 12 kick in the pants.
  9. I can do one better sunshine!
  10. With the setup i did on my R31 i can lock the rears with the handbrake no problem.
  11. http://www.johnnyspages.com/speedboats_files/cindy_resurrected.htm
  12. You can rotate the oil pump once unbolted to remove it, no need to take off the sway bar!
  13. Yes what Dimitri said /\
  14. Well i have rebuilt the odd car or 4 in the last 18 months, everyone has their little tricks to make work safer. I have another 67 Fastback Mustang in at the moment and after that is a 32 Ford. When you do such a high volume it's not if you hurt yourself but when!
  15. Scoota G
    L28T build
    Hell!
  16. Try checking voltage at the coil while running if you can.
  17. Saves knocking your shins on the pointy bits!
  18. I had repairs on my cylinder head and was about $100. I think that repair would be closer to $220.
  19. Dimitri had one. Send him a PM.
  20. Yes i have a head that has some extensive porting and it runs fine on the street. I run 45mm Dellortos and a mild cam. Buy it
  21. The float levels are too high.
  22. Yea i was on the webenet thingy because the weather here was terrible and i spied this tubbed monster. Fyi Simon i spent the afternoon at The Ballarat Fesitval of Motoring and then went for a yummy chocolate milkshake. Was good to have a break from a new client's 67 Fastback Mustang . . . . . how was your afternoon at work Simon? Good i hope!
  23. Welcome. Sure would like to see some shots of the rear setup!
  24. I can squeeze 63 litres in the 2+2 tank. The 2 Seater one would take 57 Litres!
  25. I have a 2+2 tank in my 260Z 2 seater.
