Engine-stand rotisserie with 240Z mounting frames. Perfect 'axis of rotation' (stall in any position and rotate with one hand)
Sutherland (Sydney South)
Has been stored under the house for 10 years
$150
Pickup only, or you arrange a courier.
I've hung onto this for years and finally got around to having an aluminium roof lining made - using the frame as a jig.
Unfortunately the pillar sections are gone so I don't see it viable to be used as a whole.
There is a lot of surface rust and worse rust in a section of the outer lip.
Free to a good home
Located in Ballarat area.
Thanks Dave. I make most of the bits at the local Men's Shed. They have a good machine shop. Bespoke machining at commercial shops is a bit pricey compared to off-the-shelf items.
Had a bit of a breakthrough on the steering today so starting to come together... perseverance is often the answer.
Interesting that the 4-link Panhard set-up I've just completed ran a similar timeline to yours.
PS. After-market LSx rocker rcovers are taller than standard. Don't get caught out on clearances.
