Vindicare
Everything posted by Vindicare
  1. Project Hugo is what you are looking for, never saw if it got finished
  2. Just the motor and injection/tuning was 30k+
  3. Anyone have any thoughts?
  4. Hey guys Model: 1973 240z L28ET Location: Busselton W.A Price and Payment Conditions: I'll put $35kono on it but im not sure what to expect let me know if it's fair? Item Condition: Good Body: Rust in drivers floor and sill area, bubbles in one wheel arch, and in one door top front. Otherwise not too bad, paint is old and has chips here and there, paint is about 19 years old. Mechanical: Running good, made 302rwhp on the dyno(hyperdrive MS), havent run it down the 1/4 Registration: Registered in WA, Due to several mods it wouldn't get over the pits without changing items(wilwoods, not engineers with the L28, no handbrake, etc etc etc) Suspension/Brakes: HSD coilovers AZC knuckles AZC 4pot wilwoods front and rear(no handbrake) DATRAT CV Halfshafts R200 open diff, have a OBX center and spare 3.9? diff to come with car RT diff mount All bushes, ball joints and bearings replaced when the coilovers were put in approx 10000km Strut braces front and rear Engine: Made 302rwHP on the dyno, when tuned on the engine dyno by Les it made 450hp, Currently running 16psi, To make more will require a bigger exhaust housing., Done roughly 6000km with the engine PMC Build motor Metal head gasket from SWM Peter completed the water bypass mod to help alleviate spot boiling on 5 and 6 Ross forged pistons 87mm Spool conrods AZC sump Wolf racing intake Trust stainless turbo manifold Tial 44mm wastegate Gt35r .63 housing, HPC coated and blanket/wrapped China spec cooler 800cc bosch injectors Sard fpr Rather expensive rewire of the ecu loom all labeled Petermac dizzy to suit the Autronic 500r cdi system and m&w double coil packs Rebuild, porting, cam all done by peter Tuned by les Collins and run in on the engine dyno Bosch 044 fuel pump 3" exhaust turbo back with 2 mufflers, dump is mild steel. Turbosmart manual boost controller for 2 boost levels on toggleswitch, currently wg pressure 10psi, or 16psi Gearbox is a RB25 item(big), with a Jim Berry organic clutch single plate, new tailshaft, mounts moved to suit box, adaptor plate, Short shifter Link to engine buid thread http://www.viczcar.com/forum/topic/7763-l28t-build/ Interior: Pretty shabby, needs new carpet/ door trims, Dash is perfect, Autometer Boost guage where clock used to be, Tacho is a Speedhut item, Seats are aftermarket buckets. Has Dapperlighting HID's classic kit Contact: Pm me on here and i'll pass on my phone number. I'll get more photo's, but there plently of the engine in the build thread. I'm sure i've forgeotten stuff Comes with Matching numbers L24(has injection and turbo, so no carbs) BAMF flares
  5. Stewart Wilkins will be worth it, will be my next set when I break these datrat ones
  6. Put it on the dyno today to give the tune a tickle, pulled 302rwhp at roughly 16psi
  7. Engine build thread http://www.viczcar.com/forum/index.php/topic,9947.0.html Engine on the dyno
  8. Fast. Need to get the tune resorted with some cold start and idle.
  9. Hey guys, Build thread has been a long time coming, and I'll add photos later. I bought the car back in May 2004 from Melbourne. It's was a long flight to look at it and a even longer one to get back(all done in one day). It was advertised as a 1973 auto datsun turbo. It was a cool car and I handed over the money later that week and the old owner dropped it off at the trucking depot for its long travel to Perth. The car was mostly standard with the addition of l20 turbo gear, supra intercooler, rb20 turbo and autronic smc controlling the whole shooting match. The first thing on my mind was to convert to manual, so I started trolling the quokka and managed to find Martin Falconer of Tuneright. He took the car, installed a rebuilt gearbox, a r200 diff, strut braces and a boost gauge. I drove it daily for a while then decided the seats were no good and installed some recaro copy buckets. I then stumbled across the wolf creek cv kit and purchased those, and got Martin to install them with some 260z stub axles. Not too long after I purchase a KAAZ LSD center and got that installed and the diff rebuilt. I drove it like that daily for a while and god it was terrible to drive without feeling like I was racing everywhere. It made some pretty horrific noises with how harsh it was and I put it down to it as to what killed my tranny. So I gave it the flick and started researching how to convert to running a rb25 turbo box(I've always had plans for more power) I purchased all the parts, gave martin instructions on how to install it and left him with it. A few weeks later I got it back, such a difference com paired to the L gearbox, it was a dream to drive, but the throw was terrible, cue old mate short shifter and all the gripes disappeared. About this time i really wanted to find the source of the banging in the rear. So a lot of emails to Datrat and I had myself a set of beefie cv's but to fit them I needed to hog out the adaptors to make it a interference fit with the stub axles. Out with the old and in with the new. Low and behold still a bang, but lesser. That killed my motivation as it was around this time I was informed of my girlfriends pregnant state. Instead in a last fit to spend some money before I had none to spend, I ordered AZC brakes and sent my struts to Otomoto to convert them to coil overs, and thus began the rebuild of the suspension. While I was there I changed all the old bushes to poly and replaced all the wheel bearings, aswell as a quick squirt of paint on the control arms. With it driving like a dream I just enjoyed it for a while. Eventually I found some money and set about my epic(for me) l28 turbo build. Everything was sent over to Peter Mac, all started out to be a budget build but as it always, inevitability it spiralled out and I ended up spending a small fortune. Quick parts list for those interested. Ross forged pistons Spool conrods AZC sump Wolf racing intake Trust turbo manifold Tial 44mm wastegate Gt35r .63 housing China spec cooler 800cc bosch injectors Sard fpr Rather expensive rewire of the ecu loom Petermac dizzy to suit the autronic 500r cdi system and m&w double coil packs Rebuild, porting, cam all done by peter Tuned by les Collins and run in on the engine dyno Bosch 044 fuel pump Unfortunately I did all the dodge $&@t to install it when it returned, after messing about for a while between moving towns, I managed to get it running. I've missed so much but it's been a long time and it's a rather long build time. Just purchased myself a welder and I hope to get good enough to fix all of my dodgy workman ship and really make it a car to be proud of. First fix my exhaust, and remake dump in stainless to suit the rest of the system, and then have a better go at the cooler and piping. Thanks for reading, I hope to throw up a heap if photos at a later date, I'll try dump all the ones I have on my photo bucket account. Thanks Aaron
  10. 4 runs, 13.6 13.7 13.7 13.4, broke a lash pad & unseated a rocker, on the tow truck . Martin managed a 12.9
  11. Martin(tuneright) said he's also going to try make an appearance in his 280zx l28et
  12. No LSD and probably won't warm the tires, may be slower
  13. 10psi, hoping for a mid high 12, but who knows, I have just over 1500km on the motor
  14. Hey guys, I'll be going down to have a go if they let me through scrutineering. See yah down there, come say hi. Red 240z l28et
  15. March 2 or 8 and I could likely make it as I'm in Perth for training
  16. Yeah they all like to have a looksie over the s30's.
  17. vague maybe, cars running, it's just a long way to go for a cruise nowadays.
  18. 'Twas a good day, good turn out of Zeds, I didn't take a camera so hopefully someone posts up some photos
  19. We'll I made the maiden voyage to Perth. Between a wedding and tomorrow I have to try find my exhaust leak. See you all tomorrow
  20. looking positive for me being there, will work out all the kinks on the drive up lol
  21. Okay I think all the problems I'm having is from tapping in to the wrong ignition source, can one of you guys tell me which colour wire to tap into and where a abouts? From the wiring diagram should it be the white/red wire from the ignition switch?
  22. 73 240z autronic smc, PMC l28et
  23. didn't have ignition source connection for ECU, it would appear that i've forgotted where a wire goes since i sent the ecu away. Jumpered to a ignition source and finally have power to the computer and fuel pump. Next step, recharge battery jump pack and keep on chugging along. old ign wire went to a plug which connected to nothing, go figure. but i'll find a better place to tap in to the good one . Im super hopeful it starts without too much prompting, was crackin for a little bit.
  24. Okay fk knows what I've done, not sure how to get comp goin, fuel pump relay is not getting power which I find odd, might have to attempt to bypass old alarm, perhaps it's not letting the relay get power, or god knows. God I hate wiring
  25. Thanks guys, I'll give all this a try tonight, if anyone has any other suggestions keep them rolling in. Thanks!
