aegean
Everything posted by aegean
  1. I keep looking ! Someone will have one lying in a drawer somewhere - I just need to get them to open the drawer.
  2. Looking for a owners handbook. Mine got wet in the December downpour and doesn't loook too good - let alone being able to open the pages. If anyone also has a (blank) service book, that would be good as well as mine got wet as well.
  3. Location ?
  4. aegean
    Motor Choices
    The 3UZ-FE is perhaps a better motor, but wouldn't be allowed under the formula for a 240. Might be good for a 260 though. I think you could go up to 4.8lt for these.
  5. aegean
    Motor Choices
    Which would exclude a 350. That is 5.7lt. Makes my suggestion of the Lexus 4lt motor just about right, and they are a damn good motor.
  6. aegean
    Motor Choices
    Lexus LS400 http://www.lexrex.net/ls400_parts.html
  7. And maybe look at installing a flex disk rather than a univeral. At least that way the flex disk will let go and not transfer all the load.
  8. I think you need to register to view this
  9. Get one of these as well - 3M Clean'n'Strip wheel. This is like a huge circular scouring pad that you mount to an angle grinder. Light pressure, slow speed and keep it moving over the panel or you will heat up the steel too much and it will buckle. This method will get the panels back to bright shiney bare steel,
  10. Would appreciate it. Please PM me if you find one. Craig
  11. I am also after one if you have a second spare, or if anyone else has one gathering dust
  12. That's why they invented the telephone and the postal service !
  13. Do you want a 240z or a 260z 2 + 2 ? It is either one or the other. There was never a 2 + 2 240z. It is also very unlikely that you will get a 240 for the price you mention. You might get a 260 2 + 2 for that.
  14. Have you got a photo of one of the "nuts" ?
  15. Don't think so. It was only a bit of fun !
  16. What year is your car ? The "flying saucer" is the EGR valve, and was fitted AFTER November 1974.
  17. You're right ! I hadn't noticed that before, but then I have only looked at the car once since I bought it in Oct '06 and it's been in storage every since. However, I will be getting it out in a couple of weeks, so will make sure I give it some POR15. Thanks.
  18. I wouldn't beat yourself up about it - we all make stupid mistakes sometimes ! Sometimes the obvious is only obvious to others.
  19. I don't have access to a copy of the wiring diagram, but a lot of manufacturers wire them up so that both sides are on different fuses - reasoning being that is one fails, you still have the other one. You should have a legend in the fuse box to tell you which fuse it is, or the owners manual. However, it may be one or more faults, with the likely cause being a faulty earth. It does no harm whatsover to clean ALL the fuses. When was the last time you did that ? Never ? Most likely. I had a 1950's car that had spent all day in an auto electricians shop to fix just this problem. I had just bought the car and it was being sorted for the roadworthy, and the lights were all over the place - high beam/low beam - all different lights on and in the end they couldn't sort it. I spent an hour or so cleaning all the fuses and earth wires at the lights, and they have been perfect ever since. Yes, this would cause one headlight to be dim.
  20. Sounds like an earth problem to me. Try taking the fuses out of the fuse box and cleaning them up with emery cloth and replace the fuses at the same time. Also follow the circuit back from the headlight and see if there are any junctions that attach to terminals. If so, take those apart and clean them up.
  21. I would suggest you buy a new set from a dealer. They are not expensive, and I'm sure will cost pretty much the same to get someone to replace the rubber. You can buy them off eBay US for less than $50 a pair, plus freight. If rebuilding engine mounts, you need to be sure of the rubber hardness as this has (hopefully) been calculated by the factory to provide flex and stability to the complete drive train, so that's also worth considering if you go down the route of getting someone to vulcanise new rubber to the mounts.
  22. I don't know if these will help, but you may be able to spot something.
  23. 2 + 2 is longer than a coupe
  24. YMW ! Shit, that's not on the list - You're most welcome !
  25. Commonly used Web Forum acronyms. Makes you wonder if we need to type anything anymore. ADN - Any day now AAMOF - As a matter of fact AFAIC - As far as I'm concerned AFAIK - As far as I know AFAICT - As far as I can tell AFAIK - As far as I know AFK - Away from keyboard AIUI - As I understand it AT - Ars Technica ATM - At the moment B2W - Back to work B4 - Before B4N - Before now BAC - By any chance BAK - Back at keyboard BBL - Be back later BD - Big deal BDP - Bloody double post BRB - Be right back BTA - But then again BTDT - Been there, done that BTSOOM - Beats the shit out of me BTW - By the way BUMP - To move a topic up CMIIW - Correct me if I´m wrong CUL - See you later DIKU - Do I know you DITYID - Did I tell you I'm distressed EMFBI - Excuse me for butting in EOS - End of story F2F - Face to face FUBAR - Fu*ked up beyond all repair/recognition FUD - Fear, Uncertainty, and Doubt FIIK = F*cked if I know FWIW - For what it's worth FYEO - For your eyes only FYI - For your information GAL - Get a life GD&R - Grinning, ducking, and running GIGO - Garbage in, garbage out GIWIST - Gee, I wish I'd said that GIYODS - Get it your own damn self GMTA - Great minds think alike HTH - Hope that helps IAC - In any case IAE - In any event IANAL - I am not a lawyer IANALH - I am not a lawyer however IC - I see ICOCBW - I could, of course, be wrong IIRC - If I recall/remember/recollect correctly IMAO - In my arrogant opinion IMHO - In my humble opinion IMNSHO - In my not so humble opinion IMO - In my opinion IMPO - In my pious opinion IOHO - In our humble opinion IOW - In other words IRL - In real life ISTM - It seems to me IYDM - If you don't mind IYDMMA - If you don't mind me asking IYKWIM - If you know what I mean IYKWIMAITYD - If you know what I mean and I think you do IYSWIM - If you see what I mean JFYI - Just for your information JIC - Just in case JK - Just kidding KISS - Keep it simple stupid KWIM - Know what i mean? LLTA - Lots and lots of thunderous applause LMHO - Laugh my head off LOL - Laughing out loud LTM - Laughing to myself LZ - Loser MYOB - Mind your own business NBD - No big deal NFW - No feasible way or no freaking way NJTH - Not just thinking here NLA = No longer available NP - No problem NRN - No reply/response necessary NTYMI - Now that you mention it OIC - Oh, I see OTF - Only the facts OTL - Out to lunch OTOH - On the other hand OTTOMH - Off the top of my head PANS - Pretty awesome new stuff PEBCAK - Problem exists between chair and keyboard PITA - Pain in the arse/ass PMFJIB - Pardon me for jumping in but PMJI - Pardon my jumping in PTMM - Please tell me more PWYP - Practice what you preach ROTFL - Rolling on the floor laughing ROTM - Right on the money RS - Real soon RSN - Real soon now RTFM - Read the freaking manual SB - Soap Box SIG - Special interest group SITD - Still in the dark SO - Significant other SOE - Silly/Stupid Operator Error SOS - Same old stuff TANSTAAFL - There ain't no such thing as a free lunch TCOY - Take care of yourself TFH - Thread from hell THX - Thanks TIC - Tongue in cheek TLA - Three letter acronym TPTB - The powers that be TSB - The Soap Box TTBOMK - To the best of my knowledge TVM - Thanks very much UAPITA - You're a pain in the arse/ass WADR - With all due respect WDALYB - Who died and left you boss WDALYIC - Who died and left you in charge WFM - Works for me WIBNI - Wouldn't it be nice if WRT - With respect to WT - What/who the WTF - Who/what the fuck WUF - Where you from WYSIWYAG - What you see is what you almost get WYSIWYG - What you see is what you get WWTTE - Well words to that effect YAFIYGI - You asked for it, you got it YDAGWYW - You don't always get what you want YGBSM - You got to be shitin' me WGWYPF - You get what you pay for YMBJ - You must be joking YSWUS - Yea, sure whatever you say
