Ld28 block with l28 turbo head??
I was reading the other day about a guy who had done a rd30 block woth a turbo rb26 head and was running 32psi boost or something
Has anyone ever thort of trying this with a L series engine?
I have recently picked up a complete LD28, normally we bin everything but the crank, however I will keep the block this time to study it in more detail ;)
Yea but deisels are built stronger cause it take high comp ratio
So maiting with petrol head would alow more boost with the stronger block
I had a bare block for a little while.
Bore spacing is the same.
Casting seems to be identical.
The only visual difference I could see was the deck height.
So how's that stronger? ???
Not sure the
Rd28 with a rb26 head the block was stronger
The strokes and bores are a bit different in the 2 as well
Ld
Bore 84.5
Stroke 83
L
Bore 86
Stroke 79
It would be interesting if a petrol head fits on, would be an easy way to get some longer rods in there while keeping "stock" l28 pistons
First the LD block is lots heaver and has a small bore and wont take a large bore  even if you try to sleeve it , i have try ed
it runs bigger head bolts witch is cool for the Rb 26 but not for the L head . and you need to mod the water ways a bit as well ,
So don't bother there is better ways to do it
cool that is the stuff we didn't know and why I have kept the block for once. But it might go to the scrap too now.
  • 2 weeks later...
you can not get a 90 mm bore with this block even with sleeves the bore is 84 standard , well you can but there is no steel holding the sleeves and would cost a shed lode to do for no advantage
