Hi Guys,
I've bought a 260z thats got a few issues that i'm trying to iron out.
One of them being that the brake lights don't work.
Well i've found the source of the problem, and that is that there is no brake light switch screwed into the pedal box mounting.
So i've borrowed one off my 240z and set about intstalling it.
Problem being that there sholuld be 2 wires with female bullet connectors floating around somewhere to plug the switch into .. but there isn't.
Can someone tell me what are the two wires that go into this switch? (Colours?)
And what part of the loom they come off..
Even a picture might help !.
Thanks in advance !
Both wires are black on my '74 car loom & also same on my spare loom; the female plug connections are a branch of the underdash loom & should be up under the dash somewhere & not too far away as the branch loom is not very long. Has some PO rigged up some other system to activate the brake lights? Can't imagine why anyone would though.
Wires for the brake light switch are black/yellow stripe and come out from the loom for the steering column (wipers/lights/indicators etc). Short with bullet type plugs.
Thanks for your help all !.
To be honest i don't know what the deal is... there is a thread for the pictured switch but its blanked off at the back. (so the switch can't poke through)
Is there another system for detecting braking on a 76 260z? as i can't see any other spots for switches.  :o
Anyway... i've wired up the switch ive got and the brake lights are working.. ive just got to drill out the hole on the weekend and install  the switch...
This car is throwing a few surprises at me thats for sure !
It had a lot of wiring work done to take the l28e.. and has battery relocation, battery isolation switch, old defunct alarm wired up etc...
headlights appear to be stuck on high beams and can't switch to low beams.. i think thats going to take a replacement stalk.
There is a bit to work out still from here. Wish me luck !
Some brands of cars have brake light switches mounted on & activated at the brake reservoir itself rather than by the pedal - has your car got a reservoir transplant perhaps? Even then, I can't see the point of deleting the Datsun one, very strange.
  • 3 months later...
Check for 12V at the brakes switch and just bypass the switch and check if all the brake lights light up. If no 12V at the switch, check fuse/holder and fusible links.
We had 12V, then it just disappeared.  So I would prefer to rewire it so i can trust it, though, after looking up under the dash, im thinking, im going to rewire the lot with a new fuse panel (blade fuses) and easier to access, but my car isnt at all normal...
