OK everyone - I pulled this rust bucket up the Clyde today and it is now at home ready to be cannibalised. All I need is diff, half shafts, companion flanges brake master, and I'll pull out the front struts and brakes to see it I want to use them.
The bonnet, 5 speed, fly, speedo cable are sold pending payment.
The good bits:
Glass is all there, except driver targa roof (there but broken).
Chrome looks fairly complete
Interior seems fairly intact
Mechanically looks all good. 250K on the clock, L28E doesn't leak and looks clean. Can't start as the dizzy cap is missing, but will compression test over the weekend.
Fuel injection setup all there
5 speed feels tight by the shifter
Rubber (seals etc.) fairly intact
there was a free TV in it!
Bad bits:
Rust. Coast car exposed the the elements.
Passengers door looks straight. Nothing else does, unless someone is feeling patient. The hatch was straight when I picked it up, but some clown has removed the bolts holding the top in, and it got caught by a gust of wind just short of braidwood and caused the damage you can see in the pic below.
Pm, e-mail andyransomATgmailDOTcom or contact on zero-four-zero-three-zero-eight-zero-zero-two-one
Andy
sweet!
Im keen on the engine (just the block/head/sump/intake manifold and the gear on the manifold) to be put on a stand and rebuilt with ARP studs etc for 15 psi. Can you list the head casting? (E88 or N42 or something)
Also keen on the rims! (need some to make my Z31 to roll around)
In Canberra too.
sweet!
In Canberra too.
Hey mate motor is yours - head casting is N42. Rims too, a bloke may be picking up the only mag that's on the car, else you can have the two light truck wheels and some other dodgy piece of crap that were on it. I'll throw the spare in if I sell the mag so you get a set of four. Call/SMS me.
You said the gearbox is sold, how about the bolts that attach the gearbox bell housing to the engine?
I'll drop the gearbox out tomorrow, and keep the bolts. Reimburse me for my postage costs and they're yours.
Gearbox, fly, dizzy, clutch and brake master sold.
Still have:
L28 + injection setup $150
Front struts/brakes - $100
Rear brakes - $50
Rear suspension + crossmember - offers
Pedal box + clutch hydraulics - $50
Tail lights - $20
Lots of other 280ZX bits.
Email / phonecall sent in regards to the engine. Still good for it
got a mate looking to put disks on the rear of his R30... any chance this has disks? are the handbrake cables siezed up at all?
Rear discs are functional, I know as one of the front hoses was cut but brakes still worked. Handbrake functional too, so I'd say the cables are OK. I'll part with the complete rear subframe inc. brakes, cables, lines, x-member, trailing arms etc. for $100, should be a fairly easy conversion. From memory when I was crawling around under an R30 years ago it looked very similar. I'm going to keep diff, halfshafts and companion flanges. I'm quite confident R30 flanges will go on the ZX stub.
  • 2 weeks later...
hi i am trying to locate 2 interior plastic grey screws that that attach the A pillar trim to the A pilar and one blue cap that sits along the top of the dash near the windscreen thanks for any assistance regards Paul
Sold:
Engine (pending payment)
Gearbox
Rear subframe
Dizzy & brake master
The rest will go to be turned into a shiny new fridge unless someone comes and grabs it.
Most stuff now will be cheap/free
E-mails don't seem to be coming through, I sent you one yesterday too.
Try e-mailing directly: andyransomATgmailDotcom
What sort of condition are the tail lights in?
I'm thinking of changing to series 2, I like the black lines that run horizontally.
How much to post them down to 3138?
Ta, Simon
  • 2 weeks later...
  • 3 months later...
hello
I am short the small ashtray on the console neat the auto shift lever. Any luck here?
could you tell me how much and incl post to Nelson Bay please.
Mickl
