was wondering why no one could open to passenger door from outside, so popped off the trim and found that the part where the handle meets the bit that works the arm to the door latch has snapped clean off.  Now need a replacement.
260Z 2 door ( if that makes any difference)
will gladly pay for all postage and handling costs
yea, got a broken one too.
seems to be a common zed problem.
maybe a group buy for a run of stronger items?
I dont even know who or where it'd be done?
Take your broken unit to a local engineering / fabrication shop and have them spin you some up, wont cost much....
Its been a long time since I busted a handle on a zed...
BUT just check if a 1600 one is the same,  im nearly sure thats what I used ,as  these are much easier to come by
I have read that 120Y handles can be used but I havn't tried it myself. I have plenty of 1600 handles so I can check how compatible they are. Just havn't got my Z here to compare them with :(
from memory the 180b handles are the same as 1600 and the casting was a little thicker
cheers
Bruce
