GregTas Posted February 17, 2021 Posted February 17, 2021 (edited) Hi folks, I'm getting a bit of movement in my firewall under heavy braking and wanted to put a brace on the front of my master cylinder. Not helped by fact the firewall was chopped a bit for dual brake cylinder set up. I'm just running a single boosted master cylinder. Has anyone made a brace or got photos of one? I'm ok with bolting one in to engine bay behind or on the strut tower, or welding bracket in if needed. The car isn't that pretty. Advice or suggestions on reinforcing firewall not required, just a design for a brace. Thanks. Edited February 17, 2021 by GregTas Quote
sexual_sushi Posted February 17, 2021 Posted February 17, 2021 The timing of this has me thinking you’re a plant by Apex Engineered Apex Engineered Instagram Quote
GregTas Posted February 17, 2021 Author Posted February 17, 2021 Yes something like that might work, but had thought bracing to strut tower might make it work better. I'm trying to come up with something that doesn't look too ugly.. I do wonder with that Apex design how well it would work with all that light weighting and how much it has reduced the stiffening. Quote
KatoKid Posted February 18, 2021 Posted February 18, 2021 Apex one looks pretty crap to me. Agree that something coming off the top strut mounts would be a better option. GregTas 1 Quote
GregTas Posted March 26, 2021 Author Posted March 26, 2021 Not pretty or light, but functional. Two bolts through wheel arch holding it in place. M14 bolt to master cylinder for adjusting up, with locknut. 260DET and KatoKid 2 Quote
GregTas Posted August 29, 2021 Author Posted August 29, 2021 On 3/27/2021 at 12:24 PM, Millerman said: Did it change the pedal feeL at all? Sorry missed you post. I haven't been on for a while. Yes it did, but my firewall had some flex because it was is chopped out a bit behind the booster. It had twin m/cs on it before. Quote
