  • 0
Carb ID - British SU HS6..but what from?
Question
Posted (edited)
So I picked up these today mounted to a N36 manifold. Apparently 240Z carbies. I didn't do much investigation as they were cheap (could me my first problem:'() and I thought they looked half likely to be ok with a rebuild and some TLC.
The ID tags read AUD 467 L&R which my research leads me to believe they are HS6 SU's which were normally fitted to a Morgan Plus 8 3.5 V8. I take it that its inconceivable that these would have been fitted from new? however am i right in thinking with the correct set up by someone who knows what they are doing, they will be suitable for my L28 fitted 260z?
IMG_6421.thumb.jpg.51e3b3e82e5463033e517f1c95ec7b53.jpgIMG_6422.thumb.jpg.3ed7b0d46917c28d3a36dbd5c0ce4ae8.jpgIMG_6424.thumb.jpg.5109547663978fe7e1f34b5bd30fa9fd.jpgIMG_6425.thumb.jpg.ed0bd2d84d0698b8c2a1b5644ad0a6ee.jpgIMG_6423.thumb.jpg.69cf3b26f4208e03faf0b19d5ffb568b.jpg
Edited by Herbie
3 answers to this question
  • 0
Yep :)
  • 0
Posted (edited)
Pretty much the same as the original Hitachi SU's, same design, same size.
Only difference is that parts for British SU's are readily available and cost a fraction of the price compared to the Hitachi's.
Edited by 1600dave
  • 0
Posted (edited)
I run HS6's. Bought mine new from SU midel. At the time it was a much easier, and cheaper option, than getting the old original SU's rebuilt.
Parts, needles ect, are super easy to source locally.
I had to ditch the original throttle linkage setup, and go with a cable, a superior option in my view. And also found the old choke cable ( solid core cable), didn't work very well with the choke mechanism, so I converted that to a stranded cable. That has its own issues, but was a better solution.
Edited by RAP260
Answer this question...
