gilltech Posted February 26, 2008 Posted February 26, 2008 Hello, Help needed to locate new 260z brake master cylinder - Brisbane; original part was re-kitted a couple of years ago but now leaks again so I just want to fit a new one (car is not mobile so will fit it myself). Bore size is 7/8" according to my manual, so could be same as 240z & 240k? Are these things available through Repco or Supercheap or a brake parts supplier, or are they obsolete & so I need to indent from the USA? Your advice would be appreciated. Cheers, GillTech Quote
C.A.R. Posted February 27, 2008 Posted February 27, 2008 No offense mate, but seriously, WHY haven't you been into a Repco or Bursons & asked? In saying that, yes I believe you can get new ones or have your old one resleved by the above company's. Quote
gilltech Posted February 27, 2008 Author Posted February 27, 2008 Yes I can get the old one re-sleeved; but that was supposedly done as part of the re-kit job (or was it??) & the job has failed, it leaks again, so now I just want to bolt in a new one of a reputable brand & be done with it. Thought I'd ask other Zed owners first if they have any recommendations for what I consider to be a pretty vital piece before I trek around asking at parts outlets if they stock bits for a 34 yr old car, as I had no luck last time. However, will try again. Quote
Moderators Zedman240® Posted February 27, 2008 Moderators Posted February 27, 2008 When I replaced mine with a 15/16 one when I converted to disks all round, I was told they were all no longer available new so I had mine re-sleeved. I'm not sure if it is true with all sizes of the master cylinders, but if it is take your original one and get it re-sleeved. I trust the Better Brakes in Cheltenham next to Moorabbin airport (depends on your location tho!) It just saves you all the trouble of going around and getting the same answers.. Quote
gilltech Posted February 28, 2008 Author Posted February 28, 2008 Thanks guys. Mine is supposed to have been re-sleeved when it was re-kitted some years ago, but must have been a crook job if it actually was, as the car has only been driven in & out of storage since. But will check around the usual parts outlets & see what is available this time round; but after last time I don't fancy my chances. I can always indent from the USA. I had an idea that the 7/8" was not the only size used. Quote
PZG302 Posted March 3, 2008 Posted March 3, 2008 As you said you were in Brisbane, give ABS at Brendale a call. They helped me a lot in sorting the master cylinder dramas I had with my circuit Z, ended up going to 1". They shopuld be able to tell you if the 7/8" MC is available and also do a cross reference on what is till being made. Quote
Scoota G Posted March 3, 2008 Posted March 3, 2008 Have you found one yet if not i know a place that can get them in. Quote
gilltech Posted March 4, 2008 Author Posted March 4, 2008 Thanks guys - I was about to try ABS but tried my local Repco first, & was surprised when a very helpful & persistent staffer managed to hunt one down (& only one) & get it in for me from someone's warehouse somewhere - it's in a PBR box, not OEM style as the plastic reservoirs are different & it has black plastic caps instead of the metal original style so no good for the concours boys, but I'm not in a position to be fussy right now. Cost was $141 (retail). So they are a bit thin on the ground as I suspected from previous experience. If I can find an OEM or Nissan one - & I'll try ABS next time I'm up that way - I'll grab it & stash it away. So thanks everybody for your input. Quote
PZG302 Posted March 5, 2008 Posted March 5, 2008 Good score.... I'm pretty sure you'll only find PBR M/C's are now available, if you can find them Quote
