Posted (edited)
Cleaning out my garage.
Here's some parts that need to go.
0.75mm oversized dished pistons $70
Clutch kit (Part numbers in pics) $130
Oil cooler $25
280ZX shortened castor rods $10 a pair
280ZX steering rack with power steering pump - might keep this
Assorted brake calipers $offers
Double master cyl $50
FI manifolds $offers
Head shims
Valve guides - assumed RB $offers
-unknown apart from numbers 13212 EAD 90 & 13313 EAD 90
S30 rear qtr windows $50
Tool bags $15
1600 oil pump $25
Bearing $5
Rods and steering arms $offers
S13 coilovers
-Fronts un opened
-Rears drilled for 280ZX mount. Will bolt on to either S13 or S130
S30 coil overs
-400lb springs
-sectioned fronts
-unkown caliper mounts
S30 adjustable castor rods
Stainless muffler $50
RB26 ITB's and manifold
Throttle bodies- $offers
-RB's, ZX's Q45
Triple air filters-
K&N $150
Generic $100
Weber jets, chokes, linkage wheels (see below for breakdown)
280ZX window switches $10
Booster & mc $20
Really prefer pick up.
Mooroolbark, Vic
Edited by luvemfast
Dude,are the S30 coilovers a full set? I can't tell from the picture. Does it include front & rear struts (complete) or just the sleeves? What rate are the springs?
I am interested int the RB26 Plenum and ITB's
What calipers are the twin pot? interested if they are mk63
I'll have a look. But I doubt it. I thought they were 4 spot?
Will MK63 be cast on them?
Full set with struts. Some have wet shocks, some empty.
There's also dummy sets for suspension shops to set up rates. These might be ready to transfer straight into struts.
Ad specifies spring rate. 400lb
You're not far from me, swing by and have a look.
pm me
Triple Weber parts.
So either 3 or 6 depending.
No splitting up sets.
Needle & seat (3) $30
Idle 60F8 (6) $12
Airs? 80 (6) $12
Tubes F2 (3) $45
Lever arms (3) $15
Throttle wheel (3) $45
Prices include shipping
can i please get a picture of the adjustable castor rods?
They're in the pic of the coilovers, in the box.
Basically, they have rod ends on them. You'll still need the mounts to the body.
  • 1 month later...
Did you confirm what the calipers were? Toyota Hilux ones usually have S12 or S12W on them from memory and weight a ton. The MK63s should have that casting stamp in them.
If the quarter windows are not taken I would be interested in them.
Look at me, just got rid of stuff now hoarding again :).
Coil overs all sold.
Calliper are not S12's or MK63.
Quarters still available
