chartoo Posted April 16, 2015 Posted April 16, 2015 Hello people, Time to sell off some of my Z horde. What I have is here is a brand new never fitted Arizona Z Car Cast Aluminum Baffled Oil Pan and New Sump gasket. It was US$499 + gasket + postage but I want $450. Postage at the buyers expense. Located in Mandurah south of Perth. My internet is a little inconsitent at the moment due to moving house but I will reply as soon as possible. Andy Here is the link and blurb http://www.arizonazcar.com/pan.html 1970-1978 NISSAN 240Z, 260Z, 280Z. This is a specially baffled pan designed to control the oil under extreme cornering, accelleration, and braking. To accomplish this it has 4 trap door baffles that only allow the oil to flow to the pickup and not away from it. The pan is a high strength casting that adds rigidity to the engine block. The deep fins on the bottom of the pan greatly increase oil cooling. This pan also adds about a quart of extra oil capacity. Also featured are 2 dash-8 plugs with o-ring for the oil drain and turbo oil return. A cast boss can be drilled and tapped for an oil temp sender . Socket head mounting bolts are included. Price: $499.00 Quote
chartoo Posted April 16, 2015 Author Posted April 16, 2015 Yeah. .. Just got back to Australia. Didn't look at the aud/usd exchange rate. It wasn't like I remember lol. Anyway good deal lol. Some pending payment. Quote
Agno Posted April 16, 2015 Posted April 16, 2015 If the sale falls through I'm all over it. I'm even local! Quote
44014 Posted April 16, 2015 Posted April 16, 2015 If the sale falls through I'm all over it. I'm even local! -__- just waiting for bank details... Quote
Riceburner Posted April 16, 2015 Posted April 16, 2015 Do they have a deeper pick up to go with the pan? Quote
luvemfast Posted April 17, 2015 Posted April 17, 2015 Do they have a deeper pick up to go with the pan? My recollection is that you use the standard oil pickup. But I may be wrong. It nearly happened once........ Quote
Riceburner Posted April 17, 2015 Posted April 17, 2015 I thought a deeper pan would have a deeper pick up. I know my pan had a longer and reinforced pick up. Quote
luvemfast Posted April 17, 2015 Posted April 17, 2015 I thought a deeper pan would have a deeper pick up. I know my pan had a longer and reinforced pick up. Are they deeper? Or just longer and wider? Been a few years since I've looked at one. Quote
dat2kman Posted April 17, 2015 Posted April 17, 2015 Are they deeper? Or just longer and wider? Been a few years since I've looked at one. Same depth, stock oil pump pickup fits, does hold mre oil, has threaded fittings for oil temp sender. A+ Would bang. Quote
Riceburner Posted April 17, 2015 Posted April 17, 2015 They hang below the cross member though, doesn't that make it deeper. Or does it hang lower due to the thickness of the cast? Quote
44014 Posted April 17, 2015 Posted April 17, 2015 They hang below the cross member though, doesn't that make it deeper. Or does it hang lower due to the thickness of the cast? From memory of looking at Jakes,Thickness of cast and cooling fins would add an easy cm or 2 Quote
